81.25mm forged piston.. what size headgasket to use? 82mm or 81.5mm?
Old Sep 1, 2006 | 12:48 PM
btech's Avatar
Default 81.25mm forged piston.. what size headgasket to use? 82mm or 81.5mm?
anyone knows?
Old Sep 1, 2006 | 12:56 PM
RedEj8's Avatar
Default Re: 81.25mm forged piston.. what size headgasket to use? 82mm or 81.5mm? (btech)
Hmm what kinda pistons are you using? I have 81.5mm bore and am running an OEM HG so i guess its 81.
Old Sep 1, 2006 | 12:59 PM
btech's Avatar
Default Re: 81.25mm forged piston.. what size headgasket to use? 82mm or 81.5mm? (RedEj8)
SRP 81.25MM PISTON, GOLDEN EAGLE RODS.
COMETIC SAID TO USE 82MM...?
I'LL ASK MY TUNER.
Old Sep 1, 2006 | 06:06 PM
earl's Avatar
Most 81mm gaskets measure out at 81.25mm so use an 81
Old Sep 1, 2006 | 06:30 PM
B18C Turbo's Avatar
Yeah most OEM gasket are bored to 81.5mm even no-name OEM style ones on ebay.
I f---ed up the wall on my freshly bored block so It had to be bored out to 82mm and I was forced to buy a golden eagle 82mm headgakaset. Gay.
Old Sep 1, 2006 | 08:01 PM
Muckman's Avatar
Moderator in Chief
Default Re: 81.25mm forged piston.. what size headgasket to use? 82mm or 81.5mm? (earl)
Honestly, does it really matter if your head gasket is smaller than your bore? 99% of all big bore motors on this forum are using heads with stock sized head chambers anyways. ie 84mm B18 with stock 81mm head. The piston top is below the deck at TDC so would it make a difference if a stock head gasket was used on a big bore block?
Old Sep 1, 2006 | 09:11 PM
B18C Turbo's Avatar
wait, are you saying I blew $100 for nothing? Why would they even make bigger bore HG's?
Old Sep 2, 2006 | 07:20 AM
earl's Avatar
Default Re: 81.25mm forged piston.. what size headgasket to use? 82mm or 81.5mm? (Muckman)
You really don't want the head gasket exposed to the heat of the combustion chamber if you can help it. That can cause a potential hot spot for the chamber that could lead to a head gasket failure.
Old Sep 2, 2006 | 09:08 AM
Muckman's Avatar
Moderator in Chief
So the inside diameter will melt itself to the right size automatically. lol
E85B18
Oct 3, 2009 09:02 AM
Honda_Tech01
Jun 23, 2008 08:42 AM
timm099
Jan 15, 2007 08:52 AM
ge_itr
Jan 9, 2007 08:58 PM
d mafia
Nov 9, 2001 02:27 PM
