Just did swap, distribuiter probs....
Old Apr 28, 2002 | 06:15 AM
94HybridEX's Avatar
Default Just did swap, distributer probs....
Hey guys, I just swapped a 95 LS into my 94 EX. I used the LS ECU. The engine turns but won't fire. We checked spark, nothing coming out of the distributer. Now, my question is, will my distributer from my D16Z6 work on the LS? If not, do I have to get an LS dist or will any B-Series work? Thanks alot!
EDIT: SP error in title
[Modified by 94HybridEx, 7:16 AM 4/28/2002]
Old Apr 28, 2002 | 10:17 AM
flat-blk-HB's Avatar
Default Re: Just did swap, distributer probs.... (94HybridEx)
check the ground on the thermostat housing, hell check all your grounds,fuses ETC. that was my problem with my swap.
rrroy6495
May 22, 2009 07:04 AM
