backwards heater hoses = coolant leak?
Old Sep 1, 2006 | 12:05 PM
yOnKiNaToR's Avatar
Default backwards heater hoses = coolant leak?
i noticed that after i dropped the engine back in my car that i was getting a leak from this grommet\heater hose. i also noticed that according to this pic from slhondaparts.com, the two heater hoses are switched. would this cause the leak? could it hurt the heater core or cooling system? can somebody check there car to see how its rigged? (just to make sure slhondaparts schematic isnt wrong).
Old Sep 1, 2006 | 12:10 PM
MadCityLude
Guest
Posts: n/a
Default Re: backwards heater hoses = coolant leak? (yOnKiNaToR)
The schematic is correct according to my setup. That schematic is also the same as the Helms so it is prolly correct. However I do not know if it is going to hurt anything.
daoshao's Avatar
since its leaking...why not just replace the hoses and have them installed correctly. If you don't have them in correctly i would assume you'd have no heat.
Old Sep 1, 2006 | 12:35 PM
yOnKiNaToR's Avatar
Default Re: (daoshao)
actually, i do have heat. i'm gonna try not to replace them b/c they are expensive (30 bucks for that grommet and one hose)
Old Sep 2, 2006 | 11:56 AM
yOnKiNaToR's Avatar
Default Re: (yOnKiNaToR)
i'd buy some generic hose from an autoparts store but they might kink from having them bend to theire places. i guess i'll just fork out some cash for 'em
Old Sep 20, 2006 | 10:46 AM
yOnKiNaToR's Avatar
hmmm..any of you guys look in your helms? the diagram at slhondaparts.com looks to be backwards according to the helms. anybody concur?
Sean Jackson
Feb 10, 2018 07:45 AM
LGxGirL
Nov 26, 2012 10:58 AM
lilshady6796
Jan 15, 2009 11:02 PM
