Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2005 Civic LX Fuel Gauge Problem
Old Sep 1, 2006 | 10:45 AM
jimeby's Avatar
Default 2005 Civic LX Fuel Gauge Problem
When ignition is turned on, Fuel Guage goes to full and stays there, regardless of how much is in the tank. Pulled connector on Fuel gauge pickup (under rear seat cushion), according to the Honda Service Manual sender is OK. One wire goes to good ground, but the other has +12 volts on it, even with ignition turned off! Sounds like a crossed wire, but where?
Has anyone had this problem? Does anyone know how this gauge works? The manual doesn't give me a clue.
Old Sep 2, 2006 | 06:10 PM
Todd00's Avatar
I said I don't want a title!
Default Re: 2005 Civic LX Fuel Gauge Problem (jimeby)
Did you do anything to alter it? If not, I'd take it back to the dealer to have them take a look. It should be under warranty unless you modified it.
Old Sep 4, 2006 | 11:33 AM
supermex's Avatar
Default Re: 2005 Civic LX Fuel Gauge Problem (Todd00)
I had the same problem once.
Is the floater in the sending unit.
It works just like it does on your toilet water tank , it goes up when is full and down when empty.
More likely it got stock on the full possition the lever is to close to the pump harness and it does sticks some times.
My suggestion is to take it to the dealer for service if is under warranty.
There should be no problem if you modified as long ans the mod had nothing to do with the fuel tank such a fuel pump or so.
Just don't take it to the dealer where you bought the car cause they may want to be a holes and give you a hard time if you modified other stuff.
It will be a good excuse for them not to work on your car if you have further problems
Fraser1989
Apr 17, 2014 10:30 AM
sidewayz
Sep 22, 2013 09:28 AM
andyhansana
Nov 26, 2007 07:08 AM
abeaujuin
Mar 24, 2003 02:01 PM
