EP3 - backfires occasionally
I have a bone stock '04 EP3. At 25K I pulled the airbox, filled in the ports w/ great stuff, filed the ports smooth and replaced the OE air cleaner with a K&N. This eliminated some of the silencing properties of the airbox and seemed to shift the power band up slightly (less power below 4 grand and more above 5500). All seems well with only a loss of about 2-3% efficiency (27-29MPG) during daily driving. The only issue I have is that it will backfire very occasionally. The 8-10 times this has happened in the past 28k miles the situation is ALWAYS the same…it occurs between the 1-2 shift at full throttle but shifting at 3-4k revs. BANG, but hot real loud. More like POOF. Every time I pull the air cleaner I notice that it has carbon on it in one distinct location. I have not tried going back to the OE air filter (will try next), but have wondered if there isn’t enough backpressure during the 1-2 shift described above.
Any thoughts?
Any thoughts?
the same thing happens to me. I have Top Fuel C/F intake. the filter is old though. When I get the POOF sound the car loses power. It happens when I shift 1-2 around 3k-4k rpm. WTF is that. Sounds like its coughing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jjermzz »</TD></TR><TR><TD CLASS="quote">the same thing happens to me. I have Top Fuel C/F intake. the filter is old though. When I get the POOF sound the car loses power. It happens when I shift 1-2 around 3k-4k rpm. WTF is that. Sounds like its coughing. </TD></TR></TABLE>
Never heard mine do that.
i started to get it occassionally. it sounds like a discharge from the intake though.
aem v2 sri
the common thing between all of us is an intake
aem v2 sri
mholt,
You said that you have 50km (not miles) on the car. Just out of curiosity, which EP3 / motor do you have? Si SiR Sport TypeR? K20A123...?
Modified by jpstewa at 12:06 AM 9/24/2006
Not sure if you need it or not, but this chart has the Car/Motor cobinations for ref:
http://www.k20a.org/upload/Kserieschart.htm
My old junk(see sig) did the same thing.Any of you guys have a problem with the car stumbling/bucking/missfiring badly in the rain?I remember there were a TON of people on EpHatch that did a couple years ago....
I am doing the 60K service this weekend. I will replace the K&N filter with the OE filter and see if there is a change. Will advise...
Jay
Jay
I did the 60K major service today, replacing the air filter element with the OE filter. So far so good, but I will know more after I get more miles on it.
OK, I am about at 65K. The past 5k has produced only one backfire. It seems that the OE filter put enough backpressure in the air box to keep the backfires from occurring. I am sure that the only time that it did occur was due to my having modified the air box. That is great and all, but there is a slight loss of power in the upper revs as a result of the OE filter.
Yeah, we've talked about this before. The EP3, for some odd reason, tends to do this with a modified intake. Most popular place is the 1-2 shift.
It won't really hurt anything.
RedlineMotive
17
Sep 3, 2009 05:56 PM
