H22 Rod bolts? ARP? Anyone?
Are there any options out there for an upgraded rod bolt, WITHOUT an aftermarket rod.
Do not say use an aftermarket rod, I am not able to use an aftermarket rod for what I am planning.
TIA
TIA
Ok I posted this on another post also, I am rebuilding my engine. I took my jdm h22a rods into my machinist yesterday to get re sized...I also gave him a set of GSR 9mm ARP rod bolts that I thought would work. I said let me know if they worked. I called him late yesterday. He punched a stock one out and measured and fitted etc...he said they will work and I will have the set done tom. morning...which is today...I will post the pix up when I get them back...
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExplicitSpeed360 »</TD></TR><TR><TD CLASS="quote">Ok I posted this on another post also, I am rebuilding my engine. I took my jdm h22a rods into my machinist yesterday to get re sized...I also gave him a set of GSR 9mm ARP rod bolts that I thought would work. I said let me know if they worked. I called him late yesterday. He punched a stock one out and measured and fitted etc...he said they will work and I will have the set done tom. morning...which is today...I will post the pix up when I get them back...</TD></TR></TABLE>
well picture explains it all...GSR 9mm ARP rod bolts work on the H22A rods...on the left is my beefer JDM H22A rods with the GSR 9mm ARP bolts. On the right is my old JDM H22A rods but smaller less beefer rod. The one on the right (beefer arp bolts) is going into my rebuild so should be good with a lil Nitrous maybe...
The GSR rod bolt is a lil longer then the H22A rod bolts but I dont think the clearances are that close even if they are die grinder will fix that...
gstrudler
Apr 19, 2012 09:39 PM
itr_henrik
14
May 25, 2007 02:08 AM
