90 accord problem
Old Sep 1, 2006 | 12:57 AM
djkdawg's Avatar
Default 90 accord problem
car starts, runs and idles fine, but when i come to a stop at like a stop sign or street light, it cuts off, but will start back up and drive off, but soon as i push the brake to slow down or stop it stalls and then cuts off, any ideas ? i have a new exhuast system, and spark plugs, just changed the oil, and main relay ?????
Old Sep 1, 2006 | 06:29 AM
hondadude's Avatar
Default Re: 90 accord problem (djkdawg)
not main relay this time LOL
What is the idle speed with the engine warm and car in park?
If the idle/rpm takes a dive when the engine is warm and in park/neutral it is usually a sign of a vacum leak. The brake booster uses a large amount of vacum when you step on the brake.
You could also check to be sure the screen on the EACV are not plugged up with crud.
Old Sep 1, 2006 | 09:05 AM
djkdawg's Avatar
Default Re: 90 accord problem (hondadude)
it doesnt idle up and down while in park or N , i had that fixed last year, but imma check the eavc
Old Sep 1, 2006 | 11:16 PM
Dc-5...attacK's Avatar
did you check your battery terminals
Old Sep 3, 2006 | 04:18 PM
djkdawg's Avatar
Default Re: 90 accord problem (Dc-5...attacK)
when it dies, the power stays on, all lights and music
wbaldwin_86
Nov 19, 2011 01:26 AM
wasabijim
Dec 27, 2010 03:00 PM
supertuner91ef
Dec 20, 2007 05:40 PM
djkdawg
Sep 27, 2006 02:45 PM
skata89
May 21, 2006 06:23 AM
