hazy head lights...
my headlights are all foggy n stuff. I used this polish stuff n it took it away but as soon as they got wet they fogged back up again.. I dont wanna keep buying this stuff to keep them clear. Is there a wayI could keep them clear after I got them clear? Like would putting a clear coat over it be ok or would that hurt them?
sorry it took so long to reply... but uhh yeah it's on the outside. I used this plastic polish err sumthin n it took it away but as soon as you wash your car the stuff gets cleaned off (I'm assuming) n then the hazy yellow-ness comes back slowly but it seems to jus get worse. it's kinda annoying.
I've never had that problem on a honda, but on my laser the same thing happend to the headlight
I used a Turtle Wax rubbing compound and then i used Meguiars PlastX plastic polish
Worked pretty good, If u take the time and do it, it will come out really good
You need to hit that thing with a porter-cable random orbital with a cutting pad and some heavy polish. Then finish with a light-cut pad and lighter polish.
You can have like-new headlights after this process. Check the detail forum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai »</TD></TR><TR><TD CLASS="quote">that flitz ball works really well at removing that crap</TD></TR></TABLE>
i hate that thing, probably because i can't get it to work
there's a coating on the surface that keep it from getting fogged up, if you sand/polish the lens, you will remove the coating.
you can wax it all you want but if you really want to get rid of it for good, use a light coat of clearcoat
i used to be a detailer at a honda dealership and the most cars that had them were civics and accords. the 96-2000 civics and 94-2002 accords. thats sun damage happening to the headlights. the headlights have a clear coat on them when hey are bran new and i wax my headlights around once every two weeks. When ever this sun damage would occure i would wet sad the head lights then i would buff them and they cam out looking brand new..
FourthGenHatch
17
Nov 23, 2005 09:41 AM
HXvtec
Feb 2, 2004 09:05 PM
