1995 Accord Shutters/Shake
1995 Accord Coupe Stock EX Automatic
Vehicle shakes/shutters at load during take off only in First and Second gear. Car drives fine and smooth on the express way and also if you give it more gas at a full stop.
Im guessing, since i don't know much about these obd1 5th gens yet, but maybe the EGR valve and ports since they're known to go bad...but i have no CEL's or anything indicating this either
It's more like a misfire, but where to find it? I've replaced the spark plugs already and did an oil change. Wires, distributor rotor, or clogged injectors?
Anyone else have this or similar problems?
Thanks in advance.
EDIT: The front end is all tight and the wheels all balanced. Got an alignment with the new outer/inner tie rods less then a month ago. This is not a suspension problem.
Thanks in advance.
Big_Eddy
Apr 3, 2017 04:36 AM
Runner79
Jul 28, 2010 10:41 AM
RAYThOM
Sep 3, 2005 07:12 PM
