Warm start issues?
Old Aug 31, 2006 | 06:38 PM
bagpipe goatee's Avatar
Default Warm start issues?
I know this must be a common problem, seeing as both my beater and my GF's car have it, but search is down right now.
Anyway, I know the problem is related to DPFI, which I admittedly don't know as well as MPFI.
Sometimes, when the car is turned off (or killed...) it doesn't like to restart immediately, leaving you waiting around until it will start, sometimes holding up traffic.
The computer pulls up the fuel injector code, but the connections on them are good. and I doubt both fuel injectors are malfunctioning at the same time. Any DPFI gurus know what i'm talking about? I'm thinking of pulling the main relay and checking the solder on it, even though I doubt that's what it is.
Thanks, Casey.
Old Aug 31, 2006 | 07:00 PM
mahatma's Avatar
Default Re: Warm start issues? (bagpipe goatee)
well the dual point uses a main injector and an auxillary injector.
*i believe* the auxillary only comes into play at WOT
so maybe your primary injector is pooping out. you don't floor it when you're trying to start it, right?
it dies in traffic??
Old Aug 31, 2006 | 07:08 PM
I've tried flooring it, I can't tell if it helps or not, though.
It doesn't die on it's own. It just sometimes doesn't restart if you kill it without waiting a few minutes. The symptoms also occur with shutting it off and trying to start it immediately.
The hardest part is that it's intermittent, so that when I mess with something, it usually seems to fix it, but doesn't really.
Old Aug 31, 2006 | 11:31 PM
owl bump?
Old Sep 1, 2006 | 02:15 AM
TeamRedline89Hatch's Avatar
Default Re: (bagpipe goatee)
i had this problem, but it was my o2 sensor that was bad. replaced it, boom, fixed.
Old Sep 1, 2006 | 02:22 AM
Caleb V's Avatar
Default Re: (TeamRedline89Hatch)
I don't know what to tell yah, my base model hatch used to eat o2 sensors and Map sensors all the time, it still does after I sold it to my gf a while back, yeah, yeah before she was my gf I would have given it to her now. I got the injector code once and replaced both from the junkyard, an easy way to test them is get an extra pigtail for the injectors and briefly hit it with a 9volt battery, as soon as it clicks let go of the lead. They are a b*tch to get out of the injector body though after sitting for 15-18 years. Good luck with that you will easily break them so go to a junkyard with quiet a large selection. My guess is possibly you are bleeding off fuel pressure somewhere in the system when the car warms up, bad injector o-rings etc., after you check your main relay that is.
Old Sep 1, 2006 | 08:42 AM
TeamRedline, did you have the o2 sensor code? I'd love it if this fixed it. My GF's car for sure has it's original, it's barely used.
Old Sep 1, 2006 | 08:55 AM
SVOboy's Avatar
I had this a few times with dpfi, then again with mpfi, then I realized after about a year it was my main relay dying.
Old Sep 1, 2006 | 09:21 AM
That's what I like to hear. Thanks SVO.
si vtec ftw
Jul 11, 2010 08:03 PM
efcivic92
May 22, 2009 05:48 AM
Voodooboy520
Jun 23, 2007 02:40 PM
thirteen20CRXSi
12
Jul 3, 2006 07:27 PM
SiRkid
Sep 17, 2003 08:38 PM
