SRS light
Old Aug 31, 2006 | 06:33 PM
jdmunzip's Avatar
Default SRS light
i was following gf and she told me my pass headlight wasnt working, so i looked at the fuses and the light fuse was burnt. i didnt have any 10 amp fuses and wasnt by a store to i took out my srs light fuse and used it til i got the the store and put the original fuse back into thr SRS spot, now the light wont go off.. can someone please help me?
Old Aug 31, 2006 | 08:41 PM
CustomX113's Avatar
Banned
where in great mills md are you located, what do you drive? i go through there everyday, try resetting the system and unplug your battery for a few min
Old Aug 31, 2006 | 09:33 PM
Eran's Avatar
HT White Ops
You need to do an SRS reset. Search for it, you can do it with a paperclip and a friend.
Old Aug 31, 2006 | 10:14 PM
HCJDM1's Avatar
Default Re: (95dxb18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dxb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">where in great mills md are you located, what do you drive? i go through there everyday, try resetting the system and unplug your battery for a few min</TD></TR></TABLE>
yeah unplug the battery ... i would try unplugging the the battery and takeing out the fuse .. before you reconnect the battery put the fuse back in .
Old Sep 1, 2006 | 12:41 AM
JICEK9's Avatar
Default Re: (HCJDM1)
1. remove guage cluster
2. remove SRS light bulb
3. install guage cluster
4. drink beer
but in all serious, search for the paper clip thing. or get a hold of a scan tool.
Old Sep 1, 2006 | 02:27 AM
Harryflores's Avatar
Default Re: SRS light (jdmunzip)
remove SRS light bulb that's a nOOb answer !
do a SRS reset... it has been covered before !!!
instead of using a MES Connector (Memory Erase Signal Connector) P2 use a paper clip.
then get a
Old Sep 1, 2006 | 02:31 AM
JICEK9's Avatar
Default Re: SRS light (Harryflores)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Harryflores &raquo;</TD></TR><TR><TD CLASS="quote">remove SRS light bulb that's a nOOb answer ! </TD></TR></TABLE>
it was a joke. watch who you call a NOOB. i've been a member for YEARS. unlike YOU. or are you to illiterate to understand my first post? nice try jackASS!
Old Sep 1, 2006 | 02:36 AM
Default Re: SRS light (JICEK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JICEK9 &raquo;</TD></TR><TR><TD CLASS="quote"> i've been a member for YEARS. unlike YOU. </TD></TR></TABLE>
Who cares ??
if you been here for years how come you give him shitty advice?
Old Sep 1, 2006 | 02:46 AM
JICEK9's Avatar
Default Re: (JICEK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JICEK9 &raquo;</TD></TR><TR><TD CLASS="quote">but in all serious, search for the paper clip thing. or get a hold of a scan tool.</TD></TR></TABLE>
what don't you understand? are you ******* stupid? it was a joke NOOB.
how else can I spell it out for you? please help me help you. i gave him advise... try the paper clip thing or get a scan tool. I personally can't help him with the paper clip thing because I have a Honda scanner at my finger tips. and not some POS scanner, the $6,000 Honda one
sorry for this poster... I HATE internet thugs.
Old Sep 1, 2006 | 02:49 AM
JICEK9's Avatar
then get a </TD></TR></TABLE>
you gave GOOD advise. I don't understand why you try to attack me... when I was CLEARLY joking.
Old Sep 4, 2006 | 07:36 PM
you gave GOOD advise. I don't understand why you try to attack me... when I was CLEARLY joking.</TD></TR></TABLE>
Let's leave things clear - I wasn't attacking you !! Ok we cool ?
Old Sep 4, 2006 | 08:02 PM
EconoHatch's Avatar
Lets keep the insults to a minimum here....but could this possibly work even though I took off the entire wheel in exchabge for a MOMO quick release setup.....or maybe then pull the bulb or fuse???
Old Sep 4, 2006 | 08:47 PM
EeeJayEight's Avatar
Default Re: SRS light (EconoHatch)
if anything on the SRS system is missing or not functioning the light will be on.. end of story...
i have heard you can trick the system by jumpering the plugs but i dont know if that is true or not..
so in other words.. if you remove the stock srs wheel you light will go on
gsilnc
Jan 16, 2009 04:16 AM
gooproduct
Dec 17, 2005 04:58 PM
10KrpmS2K
Honda S2000
Aug 11, 2005 07:36 PM
Darkteg
Sep 26, 2001 07:59 AM
