just swapped front LCA, to 99 si's and installed front lower sway. have a question + info
Old Aug 31, 2006 | 04:34 PM
louie3252's Avatar
Default just swapped front LCA, to 99 si's and installed front lower sway. have a question + info
Hey i have a 98 dx hatch. i got some FREE 99-00 si lower control arms, mocked them up and installed them, i used moog bushings, and new sway bar down links. about 50 bucks wotha parts from the internet. worked out ok. i also had to use the 99-00 si shock forks. the weird thing is, visually when the cars on the ground the sway bar end links look like they point in funny directions. if you hold your hands out it would be like the one that gos threw the sway bar is pointing toward the engine, and down about 20 deg. should this be straight? the one goin thre the contorl arm is. just looks werid.
Old Aug 31, 2006 | 05:36 PM
just Touge's Avatar
Ask dat_flip, he did this not too long ago......pics always help too.
go2sleep
Suspension & Brakes
Jul 8, 2006 08:47 PM
racin_fool
Jan 11, 2006 08:19 PM
racin_fool
Suspension & Brakes
Nov 4, 2005 12:38 AM
deeksmooth
Dec 9, 2003 03:56 PM
PhoBichNga
Feb 11, 2002 08:15 PM
