camber kit gives bad caster?
I doubt that would be a problem as caster is the angle of the spindle from front to rear. A camber kit would have to put the bottom LCA in a bind to effect the caster any.
Some camber kits also have an adjustment for caster. Its a sliding plate the upper ball joint is on that not only moves in and out(camber), but also forward and backward(caster).
is that the ball joint style kit? where you use stock upper a arm and put a new ball joint in? if it is it will mess with caster, rotate the joint to where you have more negative caster (the ball joint is just off center of the big nut on top)to where the top of the knuckle is towards the back of the car. this is better than positive caster it will help with turn-in.
but i dont trust these kits.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18ccivics »</TD></TR><TR><TD CLASS="quote">is that the ball joint style kit? where you use stock upper a arm and put a new ball joint in? if it is it will mess with caster, rotate the joint to where you have more negative caster (the ball joint is just off center of the big nut on top)to where the top of the knuckle is towards the back of the car. this is better than positive caster it will help with turn-in.
but i dont trust these kits.</TD></TR></TABLE>
yeah thats what i have! i get my car aligned at the honda dealership and i dont think they know how to adjust it. one side of my car has bad caster
but i dont trust these kits.</TD></TR></TABLE>yeah thats what i have! i get my car aligned at the honda dealership and i dont think they know how to adjust it. one side of my car has bad caster
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Froth »</TD></TR><TR><TD CLASS="quote">Bad caster is almost always a sign of some sort of damage to the suspension system.</TD></TR></TABLE>
if your suspension is stock, if it is adjustible then it needs adjusting.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LagunaSecaEG »</TD></TR><TR><TD CLASS="quote">
yeah thats what i have! i get my car aligned at the honda dealership and i dont think they know how to adjust it. one side of my car has bad caster</TD></TR></TABLE>
i just found out too that honda cant align the rear of my car so they have been charging me 70 bucks for a front end alignment, worst part about it is i was employed there.
jdmeg6honda
Suspension & Brakes
Apr 16, 2011 10:25 AM
