BRAKE LIGHTS WONT TURN OFF, CAR WON'T START, HELP!!!!!
My headlight switch is off, my key isnt even in the ignition, and nothing is keeping the brake down.. this has caused my battery to die and its really frustruating me.. does anybody know what i should do???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin98civic »</TD></TR><TR><TD CLASS="quote">replace the brake light switch, its like a little button the brake pedal arm pushes, probably stuck in.</TD></TR></TABLE>
pretty much sums it up.
It should be a little blue piece (its what pushes that switch in for the lights to go on) Check on your floor somewhere, it more than likely broke off. Its a simple $5-6 piece from Honda, only it will/should be a white piece since they changed the color due to heat corroding blue faster. Until you get this fixed, its best you keep disconnecting your battery everytime you get out of the car. But get this done asap...its very simple
courtney42
10
Jul 10, 2009 06:13 AM
