how would i go about checking this CEL
Old Aug 31, 2006 | 03:02 PM
ShagPower's Avatar
Default how would i go about checking this CEL
alright so my b16 swap is done, but i dont think vtec is engaging. When i turn the car on everything is normal..i drive around for a bit then when i take it up to about 6-7000RPM i get the check engine light. If i turn the car off it goes away.
should i just shut the car off then check the code (because it doesnt appear when i turn it on)
Old Aug 31, 2006 | 03:05 PM
G2 Speed's Avatar
Default Re: how would i go about checking this CEL (ShagPower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShagPower &raquo;</TD></TR><TR><TD CLASS="quote">alright so my b16 swap is done, but i dont think vtec is engaging. When i turn the car on everything is normal..i drive around for a bit then when i take it up to about 6-7000RPM i get the check engine light. If i turn the car off it goes away.
should i just shut the car off then check the code (because it doesnt appear when i turn it on)</TD></TR></TABLE>
Yes, check the code..
you got enough oil in there, and.. is your engine warmed up.. and pressure built
Old Aug 31, 2006 | 03:09 PM
ShagPower's Avatar
Default Re: how would i go about checking this CEL (G2 Speed)
should be, this is after driving around for 10-15 mins..engine temp is on the halfway normal mark..speedo works...
G2 Speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShagPower &raquo;</TD></TR><TR><TD CLASS="quote">should be, this is after driving around for 10-15 mins..engine temp is on the halfway normal mark..speedo works...</TD></TR></TABLE>
so it's not oil pressure..
Pull the code
Old Aug 31, 2006 | 05:53 PM
ShagPower's Avatar
checked the solenoid and it clicked, so it is working...then i went to crappy tire and bought some octane boost (i had 89 in the tank from the d15) ..and now vtec is working '
however still getting the code, i'll check it tomorrow and post it.
Old Aug 31, 2006 | 05:57 PM
EGwhat!!!'s Avatar
when the cell comes on dont turn off the car check the cel while car is running
Old Sep 1, 2006 | 02:25 PM
ShagPower's Avatar
was getting code 20 and 23 (ELD and knock)
fixed the knock sensor (bad wiring..my fault) and i dont even have an ELD in my fuse box so i'll have to suffer with it for a bit..or get a chipped p28
blaze.1
Sep 24, 2009 11:04 AM
scoobyjr56
Sep 26, 2006 06:47 AM
scheistermeister
Feb 21, 2006 01:19 PM
JThrasher79
Dec 29, 2005 02:28 AM
lilxvtecxpwr
Oct 13, 2002 11:04 PM
