Mini-Me A6block/Y8 head questions
Old Aug 31, 2006 | 11:38 AM
VtecKiDD's Avatar
Default Mini-Me A6block/Y8 head questions
Ok so we are building a Turbo SOHC D series. Ive been searching on HT an came across alot of threads but some people seem to be divided on some issues so i decided to make another thread.
Heres the setup:
D16A6 Block
CP Pistons 9:1
D16Y8 Head
Now, some people say to run the 92-95 Civic Timing belt, others say run the timing belt that matches the head. Some people say the Y8 and Z6 timing belts are on the loose side? anyone have a DEFINITE answer?
What Headgasket is PREFERRED. ive heard some say the z6 is the best, but the y8 is thinner?
Whats this issue about the y8 timing? Does the y8 throw the cam timing off on a D16a6?
Cliffs:
What timing belt for D16a6 with Y8 head?
What water Pump for D16a6 with Y8 head?
What headgasket for D16a6 with y8 head?
thanks in advance
Old Aug 31, 2006 | 11:56 AM
njn63's Avatar
Default Re: Mini-Me A6block/Y8 head questions (VtecKiDD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecKiDD &raquo;</TD></TR><TR><TD CLASS="quote">
Cliffs:
thanks in advance</TD></TR></TABLE>
y8 timing belt, a6 water pump, y8 headgasket.
That's my setup at least.
Old Aug 31, 2006 | 02:54 PM
VtecKiDD's Avatar
Default Re: Mini-Me A6block/Y8 head questions (njn63)
People say the Y8 belt is too tight. I keep reading that the DX timing belt is a better choice.
Thanks though
Old Aug 31, 2006 | 04:15 PM
1990si's Avatar
i run the y8 timing belt on my a6 block. it works out fine. and i also have the y8 mini me swap. pm me if you got questions bro i just got done with the swap pce.
Old Aug 31, 2006 | 07:20 PM
njn63's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecKiDD &raquo;</TD></TR><TR><TD CLASS="quote">People say the Y8 belt is too tight. I keep reading that the DX timing belt is a better choice.
Thanks though</TD></TR></TABLE>
i have an a6/y8 mini-me in my car with a y8 timing belt. No issues here.
Old Aug 31, 2006 | 07:27 PM
VtecKiDD's Avatar
you guys runnign the Y8 distributor or the a6. Ill be converting this EF to OBD1, so i figured you would run the y8 dizzy pinned to OBD1.
damn this **** gets confusing lOL
Old Aug 31, 2006 | 07:32 PM
1990si's Avatar
yea i was cheap at the time and just got a vtec controller. and i used the a6 dizzy. i got an air fuel gauge and when vtec kicked in it didnt lean out like people say.
Old Aug 31, 2006 | 07:38 PM
VtecKiDD's Avatar
Default Re: Mini-Me A6block/Y8 head questions (1990si)
this one is gonna have rods, pistons, our custom turbo kit. ill be posting a write up on it in a few days. shooting for 350whp
i just havent ever done a mini me before, so i was just trying to get info.
Old Aug 31, 2006 | 07:56 PM
njn63's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecKiDD &raquo;</TD></TR><TR><TD CLASS="quote">you guys runnign the Y8 distributor or the a6. Ill be converting this EF to OBD1, so i figured you would run the y8 dizzy pinned to OBD1.
damn this **** gets confusing lOL</TD></TR></TABLE>
I'm running a obd1 non-vtec dizzy (1.5L) on mine. The only odd-ball distributor is the z6 it seems.
If all you're doing is engaging vtec without the proper ecu, you're wasting your time. Trust me. I ran obd0 for a year before finally going obd1. Car is day and night different. Picked up about 5 tenths at the drag strip and that was the only mod done between the 2 trips (actually picked up 7 tenths but i'm sure driver/weather had something to do with a couple of them )
Old Aug 31, 2006 | 08:00 PM
1990si's Avatar
lol u got a vtec username and dont even have vtec lol
Old Sep 1, 2006 | 07:56 AM
VtecKiDD's Avatar
Default Re: (1990si)
Well i HAD a 237whp NA lsvtec.
This D series **** is new to me
dohc4life
Aug 14, 2010 08:50 AM
civicshowracing65
Sep 16, 2006 12:13 PM
DA91TEGGY
Apr 19, 2005 03:55 PM
senpai
Jul 26, 2004 03:33 PM
lohatch
Jun 15, 2004 07:44 AM
