spark plug wires compatability
i was looking at some magnecor wires for my 95 ex online and they list 92-00 civics under the same part number... does this sound right?? sohc civic wires are interchangeable with sohc acord wires?? can anyone confirm this??
thanks
thanks
They should be about the same length and all, and there really shouldn't be any difference in resistance between the two. I used some H22 Magnecor wires on my F23 before.
Pretty much wires are wires. You want to insulate the charge from shorting to ground before it gets to the plug, and have a resistance that is within spec for your ignition system. Wires that are too long add extra resistance, are prone to chafing and shorting, and look just plain crappy. OEM is more than adequate in in all but the most demanding applications, and they fit and look good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicboisi »</TD></TR><TR><TD CLASS="quote">i bought some Belden wires for my 93 EX accord and they didnt work on the 95 so im not too sure
Double check it</TD></TR></TABLE>
well i am specifically talking about compatability between 92+ civic wires and 94-97 accord wires.
well my stocks suck and i have never had probs with GOOD aftermarket wires like magnecor, ngk and nology. worth the money for the quality and piece of mind. just my 2 cents
don't see why they wouldn't work I know if you buy a msd distrutor cap it says it fits all hitachi distributors which includes civics, what I'm trying to say is the caps the same the only diference in the wires would maybe be the lenth between the connectors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKFLSH »</TD></TR><TR><TD CLASS="quote">Why do your stock wires suck? What is the problem with them? Not the right color?
Stock wires are ngk, I do believe. Very good.</TD></TR></TABLE>
they are old and need replaced..
So get some new ones. You can buy whatever plug wires you want. I'm just saying the OEM plug wires are as good as any of the aftermarket wires, and you know they will fit right.
