quick cam timing question
Old Aug 31, 2006 | 10:07 AM
boonacka's Avatar
Default quick cam timing question
if a head is milled, do you set TDC with the cam at 0 Degree setting or at the advanced Degree setting? here's a pic to explain what i'm asking.
Old Sep 1, 2006 | 04:50 AM
boonacka's Avatar
Default Re: quick cam timing question (boonacka)
common tech gurus!
Old Sep 1, 2006 | 04:58 AM
audiimportech's Avatar
i would think at 0 degrees. but i am a little confused by what you're asking. did you just mill the deck? if so then i would say 0 but that's my opinion
Old Sep 1, 2006 | 05:08 AM
mmuller's Avatar
Mad Scientist
for every 1mm you mill is about 1.14 degrees the cams get retarded.
Old Sep 1, 2006 | 05:23 AM
boonacka's Avatar
Default Re: quick cam timing question (mmuller)
ok guys thanks for you input but thats not what i'm asking. I understand that the cam must be advanced so so 1 degree for ever 1mm blah blah. but the question i'm asking is:
at which configuration should you use to set TDC?
Old Sep 1, 2006 | 05:50 AM
boonacka's Avatar
heres a better pic of what i'm asking.. this should be more clear.
If you rhead is MILLED, do you set TDC with the INNER or OUTER marks of the CAM GEAR??
Modified by boonacka at 10:09 AM 9/1/2006
Old Sep 2, 2006 | 06:02 PM
91SiZ6's Avatar
Loosen your cam gear adjustment bolts, set the crank pulley to TDC on #1 (make sure the distributor rotor is pointing at #1 as well), and tighten your cam gear bolts. Your cams have now been ghetto degreed to zero.
Old Sep 3, 2006 | 08:26 AM
postman's Avatar
the proper way is to use a degree wheel and set tdc.
Old Sep 3, 2006 | 08:26 PM
91SiZ6's Avatar
Hence the term "ghetto degreed".
Old Sep 19, 2006 | 11:06 PM
ah789454's Avatar
Default Re: (91SiZ6)
find how much what the lift must be at TDC from honda then dial them in
http://www.hondatech.com.au/fo...t=678
Old Sep 20, 2006 | 01:33 PM
91SiZ6's Avatar
Holy labor intensive. Not to mention, how many people have three dial bore gauges hanging out in the garage? I don't even have one yet...yet.
Old Sep 20, 2006 | 08:04 PM
JimBlake's Avatar
No, I don't agree. With the crank at TDC, you want the cam right on the mark.
Problem is, after you've milled the head, you'll find that you need to position the camshaft sprocket at some fraction of a tooth.
Its like your third picture. The sprocket can't be positioned perfectly because it would have to be in-between 2 belt teeth. So you have to compensate using the adjustable sprocket, to put the actual camSHAFT in the proper position.
Old Sep 21, 2006 | 02:48 PM
91SiZ6's Avatar
^^ Which is what my "ghetto" method does. Well, in theory anyway.
I should add that if I had three dial bore gauges, I'd more likely than not use the method from the link.
ratchetej1
Engine Management and Tuning
Aug 12, 2017 09:36 PM
Dustin B
Sep 20, 2014 03:59 AM
Igaly
Honda Civic (2001 - 2005)
11
Feb 15, 2009 06:40 AM
boonacka
Sep 1, 2006 10:43 AM
user 996328629
Apr 4, 2004 08:04 PM
