Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
bypassing coolant through the throttle body
Old Aug 31, 2006 | 09:53 AM
honda06si's Avatar
Default bypassing coolant through the throttle body
to bypass the coolant running into the throttle body do you just run the two hoses coming into the tb together?
Old Aug 31, 2006 | 10:35 AM
Declectic's Avatar
Default Re: bypassing coolant through the throttle body (honda90si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda90si &raquo;</TD></TR><TR><TD CLASS="quote">to bypass the coolant running into the throttle body do you just run the two hoses coming into the tb together?</TD></TR></TABLE>
perhaps you could word it so that it make sense, cuz i have no clue what your trying to ask
sounds though, as if your concerned with how close the coolant hose is to the intake arm... and air is coming in so g0t damn fast into that intake arm that it makes absolutely no difference... i
bottom line, that hose is not heating the intake arm up hot enough that the air passing by it just all of a sudden jumps in temperature because it passes by the spot next to the coolant hose
and if you anyone thinks i'm full of it, go learn some ****** physics
Old Aug 31, 2006 | 10:47 AM
honda06si's Avatar
Default Re: bypassing coolant through the throttle body (SeanJohn1802)
no thats not what im asking. when i did the img install, it had on the instructions to make the IM cooler you could bypass the coolant lines running into the TB back into the motor as long as you didnt live in too cold of an environment. is this more clear?
Old Aug 31, 2006 | 10:50 AM
Declectic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda90si &raquo;</TD></TR><TR><TD CLASS="quote"> is this more clear?</TD></TR></TABLE>
very much so... and in that cas, iono lol
but at least others will understand what your asking now
Old Sep 1, 2006 | 04:53 AM
benmunger's Avatar
yup, just run the two hoses together...
this will not make it that cool though because as i understand it, in addition to the TB, the IM has coolant running through it as well.
ska24
K Series
May 20, 2019 07:22 AM
projektcivic
Honda S2000
13
Feb 20, 2008 04:58 AM
4DRmafia
Sep 3, 2005 10:17 AM
Mentat Ghola
Aug 14, 2003 11:25 AM
oOPreludeBoyOo
Jul 13, 2003 02:56 AM
