Piston/Valve Clearance with Type-S cams
Old Aug 31, 2006 | 09:22 AM
sivikvtec's Avatar
Default Piston/Valve Clearance with Type-S cams
Can you use a thin head gasket with type-s cams and stock bottom end? I would like to increase my compression alittle by running a 1 layer oem headgasket. Has anyone one here had a setup similar to this and was ok?
Old Aug 31, 2006 | 10:17 AM
ExplicitSpeed360's Avatar
Banned.
Default Re: Piston/Valve Clearance with Type-S cams (sivikvtec)
good question I would think it might be possible but your cam adjustments might be limited?
Ac01031234
Engine Machining & Assembly
Nov 20, 2016 11:36 AM
Suck my DX
19
May 19, 2006 02:16 AM
xDicktonesx
Jul 28, 2005 12:59 AM
ChaseIntegra
May 27, 2005 02:36 PM
Used2beAb16
May 4, 2004 04:29 PM
