puting connectors on braided lines
Old Aug 31, 2006 | 09:03 AM
teler86's Avatar
Default puting connectors on braided lines
i was wondering how you put the connectors on the braided stainless lines, i am currently doing my turbo install and cannot figure it out, i have russel lines and fittings but i can not get the fitting on the line any help would be appreciated.
Old Aug 31, 2006 | 09:30 AM
thesmogman's Avatar
Default Re: puting connectors on braided lines (teler86)
Once you decide to how long you need it, use electrical tape around the braid.
Use the electrical tape where the connector goes, now you can slide the connector over the braid and electrical tape. No fraided ends.
EDIT: This is if you are using the cheepo ones with the screw type clamp.
Now that I re read your post this might not apply. But might give you an idea.
Old Aug 31, 2006 | 09:56 AM
teler86's Avatar
still confused what type is the russles?
Old Aug 31, 2006 | 10:05 AM
thesmogman's Avatar
Default Re: (teler86)
I'm not sure. Does it have a fake cap that fit's over a normal hose clamp?
Is this what you have? http://www.russellperformance....shtml
Old Aug 31, 2006 | 10:31 AM
teler86's Avatar
Default Re: (thesmogman)
this is what i have
Old Aug 31, 2006 | 11:06 AM
Trooper's Avatar
This should help
Old Aug 31, 2006 | 11:12 AM
teler86's Avatar
Default Re: (Trooper)
will try
Old Sep 3, 2006 | 05:39 PM
JDMorgan's Avatar
put electrical tape over the end of the hose and the red side on before trying to get the blue side on.
vtec.dc2
Welding / Fabrication
Nov 8, 2006 05:20 PM
Soda Popinski
Sep 11, 2005 01:56 PM
Trooper
Sep 25, 2003 09:45 AM
ILOVEGIRLS
Sep 16, 2002 02:08 PM
