B16A2 o2 sensor size question
Old Apr 27, 2002 | 07:19 PM
Qwikrex's Avatar
Default B16A2 o2 sensor size question
Ok, I have an OBDII test pipe with the o2 bung welded in it. I've heard that if I just wrap the secondary o2 sensor in aluminum foil and fasten it under the chassis that it will not throw a CEL. This leaves a hole in my test pipe. I was wondering what size screw/bolt would I need to fill in that hole if I removed the secondary o2 from the test pipe? Also, what if I just wrapped the o2 sensor in aluminum foil and still installed it into the test pipe. Would that work just as well?
IntegraCF21
Sep 24, 2005 04:42 AM
EKB18BPR3
Jul 7, 2003 10:50 AM
Qwikrex
Apr 27, 2002 08:27 PM
