GSR with type r cams
Old Aug 30, 2006 | 05:07 PM
Cyrus4g63's Avatar
Default GSR with type r cams
I have a B18C JDM GSR, I want to run type-r cams and run the type-r program.
Is this a good idea?
Is it better to run CTR or ITR cams?
And do I need anything else to do this?
Old Aug 30, 2006 | 05:25 PM
nokturnal_munkeeboy's Avatar
Default Re: GSR with type r cams (Cyrus4g63)
hi there? is that what you want run with right now. your best bet is to run with itr exhaust cam with ctr intake cam. ctr intake cam is better than itr intake cam and itr exhaust cam is better that ctr exhaust cam
Old Aug 30, 2006 | 06:04 PM
lVlemphizStylez's Avatar
Default Re: GSR with type r cams (nokturnal_munkeeboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nokturnal_munkeeboy &raquo;</TD></TR><TR><TD CLASS="quote">hi there? is that what you want run with right now. your best bet is to run with itr exhaust cam with ctr intake cam. ctr intake cam is better than itr intake cam and itr exhaust cam is better that ctr exhaust cam </TD></TR></TABLE>
not quite...the 00-01 itr cams are IDENTICAL to CTR cams
Old Aug 30, 2006 | 10:24 PM
DC2SIR-G's Avatar
* B A N N E D *
Default Re: GSR with type r cams (lVlemphizStylez)
get CTR or 00 ITR cams if u want to stick with OEM cams. if u want to run your GSR kinda like a type R set up, get a single runner manifold with a chipped ECU and a shorter geared tranny
Old Aug 30, 2006 | 10:31 PM
-Championship-'s Avatar
76.169.175.137
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">
not quite...the 00-01 itr cams are IDENTICAL to CTR cams</TD></TR></TABLE>
and to the OP, the tr's are good cams, but i would go with something more aggressive..like stage 2's, and then you'll know what all the fuzz is about...if you want to spend 500 bucks for CTR's go ahead, but just to let you know you can buy blox stage 2 and valvetrain for about 550, good luck with your set up, hope my advice helps
Old Aug 30, 2006 | 10:35 PM
DC2SIR-G's Avatar
* B A N N E D *
Default Re: GSR with type r cams (CW_98gsr)
where is this blox stage2 and valvetrain deal at??? i need to hop on that.. .and running stage 2's dont u gotta up your compresssion ratio also..:?
Old Aug 30, 2006 | 10:45 PM
76.169.175.137
Default Re: GSR with type r cams (DC2SIR-G)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2SIR-G &raquo;</TD></TR><TR><TD CLASS="quote">where is this blox stage2 and valvetrain deal at??? i need to hop on that.. .and running stage 2's dont u gotta up your compresssion ratio also..:?</TD></TR></TABLE>
up your compression?..nope, but it would be better, just get jdm b16 pistons, and your set....but this deal is only in south gate auto electic here in south gate
Old Aug 31, 2006 | 12:49 AM
Fat Chick Magnet's Avatar
CTR intake cam, ITR exhaust cam. I know a lot of people going with that setup along w/ p28 ecu or p73 96' spec jdm itr ecu which is pretty rare to find.
Old Aug 31, 2006 | 05:30 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2SIR-G &raquo;</TD></TR><TR><TD CLASS="quote">running stage 2's dont u gotta up your compresssion ratio also..:?</TD></TR></TABLE>
yes you do...otherwise youll be overcamming the motor...that cam will not be effecient on a stock bottom end gsr...not to mention youd feel like a real douche for spending 500 bucks on **** you cant use...and for the record CTR cams dont cost 500 bucks
Old Aug 31, 2006 | 09:19 AM
Jay J's Avatar
Prince of Zamunda
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW_98gsr &raquo;</TD></TR><TR><TD CLASS="quote">
up your compression?..nope, but it would be better, just get jdm b16 pistons, and your set....but this deal is only in south gate auto electic here in south gate</TD></TR></TABLE>
Word of advice pay cash there
Old Aug 31, 2006 | 04:28 PM
DC2SIR-G's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">yes you do...otherwise youll be overcamming the motor...that cam will not be effecient on a stock bottom end gsr...not to mention youd feel like a real douche for spending 500 bucks on **** you cant use...and for the record CTR cams dont cost 500 bucks</TD></TR></TABLE>
thank you
Old Aug 31, 2006 | 04:49 PM
D-meet07's Avatar
the CTR intake cam is a tad more aggressive than the ITR intake cam. Both have the same exhaust cam.
Old Aug 31, 2006 | 04:53 PM
iH8RICERZ's Avatar
Default Re: GSR with type r cams (D-meet07)
from what i understand, the 98+ itr intake cam and the ctr intake cam are basically the same exact thing. The exhaust cams are the same. If your on a tight budget, then getting oem ctr or itr cams is a good upgrade. You can't go wrong with oem parts. BUT, if you just want to do a one time install and get some actual noticeable power out of cams, i'd wait, save up a few more dollars, buy some aftermarket valve springs and retainers, and find a set of stage 2 cams (blox b's, skunk2 stage 2, buddy club spec 4's, etc.).
Old Aug 31, 2006 | 06:51 PM
jdm_bones's Avatar
Yo, is this gorge?
Old Aug 31, 2006 | 08:26 PM
Default Re: GSR with type r cams (iH8RICERZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ &raquo;</TD></TR><TR><TD CLASS="quote">from what i understand, the 98+ itr intake cam and the ctr intake cam are basically the same exact thing. The exhaust cams are the same. If your on a tight budget, then getting oem ctr or itr cams is a good upgrade. You can't go wrong with oem parts. BUT, if you just want to do a one time install and get some actual noticeable power out of cams, i'd wait, save up a few more dollars, buy some aftermarket valve springs and retainers, and find a set of stage 2 cams (blox b's, skunk2 stage 2, buddy club spec 4's, etc.).</TD></TR></TABLE>
close...its the 00-01 itr spec thats identical to the CTR's
DC2 Mang
May 9, 2006 02:09 PM
ALLmoTorB18CrX
Jun 27, 2004 09:55 AM
PowerHouse
Apr 6, 2004 10:39 PM
SoCaLNaTIvE
Sep 12, 2002 05:49 PM
quik2kSi
Jul 27, 2002 09:39 AM
