Where to get oem b17 parts?(besides dealer)
I Need a water pump/oil pump/rear main seal/oil pan gaskett/ and timing belt? I don't want to go to the dealer. Where else can i get oem parts?? its hard to find parts for the b17 at a reasonable price!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91crxturbo »</TD></TR><TR><TD CLASS="quote">I can use a b16 water pump and b17 timing belt right?? And does it matter what year(obd1/odb2)??? Like, can i use a timing belt and water pump from a 99 si??</TD></TR></TABLE>
You should try that, then let me know how a SOHC D series t-belt and water pump work on a b series. Now, if you get a t-belt and pump from a '99 SiR, you may have more luck.
Seriously though, if you are too cheap to go to the dealer, look in the phone book for local parts suppliers. OR get the Ebay special, and have the belt snap 20 mins after installing it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EK_Fanatic »</TD></TR><TR><TD CLASS="quote">You should try that, then let me know how a SOHC D series t-belt and water pump work on a b series. Now, if you get a t-belt and pump from a '99 SiR, you may have more luck.
move to the us and you might understand. your sir is our si.
</TD></TR></TABLE>move to the us and you might understand. your sir is our si.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KraZEtEggIE »</TD></TR><TR><TD CLASS="quote">
move to the us and you might understand. your sir is our si.</TD></TR></TABLE>
Skooled
Skooled
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC TWOin IT »</TD></TR><TR><TD CLASS="quote">i think soem came with gay *** sohc vtec. d16y? piece of ****</TD></TR></TABLE>only canadian ones were sohc. the ones in canada were an ex for the most part, they then had an sir model which is the same as our si model.
racingant
Dec 22, 2005 08:11 AM
