Just Changed Tranny Fluid On '02 Accord 4Cyl.......... Transmission Experts??
Old Aug 30, 2006 | 03:57 PM
B18C_EJ8's Avatar
Default Just Changed Tranny Fluid On '02 Accord 4Cyl.......... Transmission Experts??
Background info: 2002 Accord SE 4 cylinder with 57,120 miles. I'm going on a 800+ mile road trip next week, so I thought a fluid change was a good idea... I bought the car used last August, and I'm assuming that this is the first time the fluid has been changed...
The fluid was browninsh, with just a hint of red remaining... It didn't smell burnt at all, but definitely didn't have any off-smelling odors, but didn't smell like new, either...
Anyways, when I pulled the drain plug and found it coated with this epoxy-like substance... It wasn't sticky (probably because it & my fingers were coated in ATF), but it was soft...Like toothpaste consistency or a little thicker. It was also coated with a layer of fine metal shavings... Pics are below...
I didn't wipe the shavings/epoxy off, but I may do another fluid change in 50 miles so I can wipe it off then if it's suggested...
Is this normal after 57k on the original fluid?? Am I just being paranoid???
The car shifts great (nice & smooth) all the time, and I took it out for a drive after I put in 3 fresh quarts of Honda ATF, and it really didn't shift much different...
Thoughts???
Pics:
Old Aug 30, 2006 | 10:15 PM
RedEj8's Avatar
Default Re: Just Changed Tranny Fluid On '02 Accord 4Cyl.......... Transmission Experts?? (B18C_EJ8)
So wait, when you reinstalled the drain plug you didnt clean it off first?
Old Aug 31, 2006 | 01:28 AM
Jago's Avatar
Default Re: Just Changed Tranny Fluid On '02 Accord 4Cyl.......... Transmission Experts?? (RedEj8)
thats normal
Mason Edmison
Sep 7, 2017 09:14 AM
GIacona
Aug 17, 2017 05:06 PM
ZekeZG
Apr 5, 2016 01:24 PM
Carloscda1
Mar 4, 2015 10:39 PM
ezol
Mar 14, 2007 05:28 PM
