Car bogs when you hit the gas, and when driving if I floor it bogs like I am down shifting..?
anyone had this I just did a b16a swap into a 89 dx 1.5 I was thinking maybe it might be a lean condition and I am going to swap out the fuel pump also I am going to change ecu cause I have a pr3 ecu that is automatic?
Just figured I post up and see if anyone has had this prob..?
I have the same problem, but its on my d16a6, and I'm pretty sure its my ignitor in my distributor. Other problems could be a filter and or dirty injectors. Though I'm almost certain its ignitor that's bad.
Autozone can run diagnostic check on your ignitor and tell you if its bad, I think. But I am not certain, since its a pr3, and idk what dizzy you are running. I don't know if that would be a problem.
yea I am obd0 I think it is td-22 or td-44 it's obd0, but thanks I am going to try to take to autoparts place and get it tested I dont think they do that around my way though..?
I cleaned out my injectors and put new seals and still the same they are working though is there away to test them..? or tell? I think it is between the fpump and ecu though..
Yeah, I suspect its a problem with your dizzy,like the ignitor, I don't know what replacement there is for an obd 0 dizzy on ur b16, I'm not sure if you can mix and match, but why not go and find an obd0 ignitor off a b18 integra. Checker, kragen, autozone might run a check on ur ignitor, autozone offered to diagnose mine before buying. Is your tach needle bouncing around?
The Punk has me set on 10 posts a day limit, so if I have more to say, I will edit this post. Therefore read back on here to see if I respond, instead of checking for a new post from me.
i had the same problem on my d15b2 - when i pressed on gas pedal it bogged, if i floored it, it bogged like crazy.then one day my car wouldn't start up - there was no spark.my mechanic changed the ignition coil and now it works like new.
MAKE SURE YOU SWAP THE YELLOW/WHITE AND GREEN/WHITE WIRE ON THE TPS SENSOR THEY READ BACKWARDS IN A DUAL POINT SYSTEM THEN ON A MILTIPORT. FOUND THAT TO BE VERY COMMON ON SWAPS PEOPLE DID AND FORGOT TO SWAP THOSE WIRES AROUND. ALSO USE A JUMPER HARNESS ON THE DISTRIBUTOR BETTER THEN SWAPPING WIRES AROUND AND HAVE TO RUN WIRES TO THE ECU.
? I dont understand the car will bog if the tps is backwards, yel/white , gre/white. on the ecu?
88SeeOurEx
Sep 10, 2009 05:36 PM
92integracer
Oct 7, 2008 07:05 PM
if not that then check coil and igniter
