Swapping a D series into an integra?!
Old Aug 30, 2006 | 09:16 AM
inline4me's Avatar
Default Swapping a D series into an integra?!
Ok, this may sound strange, but my friend has an integra gs-r w/ no engine tranny shift linkage, ect... because he swaped it into his del sol. I am going to get the car for free and want to drop my old d15b "swap" into the shell to use as a daily driver temporaly while I am working on my GS-R. Has this ever been done (can it be done)? they are all obd2.
Old Aug 30, 2006 | 09:35 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Swapping a D series into an integra?! (inline4me)
Yes it's been done, should be straightforward as long as you're using the correct ECU for the engine.
Old Aug 30, 2006 | 09:43 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: Swapping a D series into an integra?! (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">Yes it's been done, should be straightforward as long as you're using the correct ECU for the engine.</TD></TR></TABLE>
Old Aug 30, 2006 | 10:06 AM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Old Aug 30, 2006 | 11:13 AM
escape2me's Avatar
Default Re: Swapping a D series into an integra?! (CARMA_in_da_626)
Old Aug 30, 2006 | 12:17 PM
Fat Chick Magnet's Avatar
damn how slow is the integra going to be with that motor.
Old Aug 30, 2006 | 12:38 PM
Weapon X's Avatar
Default Re: (dc2rtek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2rtek &raquo;</TD></TR><TR><TD CLASS="quote">damn how slow is the integra going to be with that motor. </TD></TR></TABLE>
0-60 in 1hr?
Old Aug 30, 2006 | 12:57 PM
GoldCoin's Avatar
Default Re: (DC4 KiDD)
make sure you print out the dyno reports
Old Aug 30, 2006 | 06:23 PM
inline4me's Avatar
Yea, This sucker was slow in my del sol, so it will really be a slug in the heavier integra.
Old Aug 30, 2006 | 07:15 PM
DCnotTHEshoes's Avatar
it fits and mounts properly with no major adjustments?
Old Aug 30, 2006 | 07:23 PM
BS 22's Avatar
Default Re: Swapping a D series into an integra?! (DCnotTHEshoes)
damn for some reason i can't find the link with that guy putting the d15 (or d16 not sure) in his ITR...
Old Nov 20, 2010 | 06:16 PM
nothing_shocking's Avatar
Hate to bring this up from 4 years ago, but I'm looking at doing this same swap in March. I have a complete 92 Civic Si with a jdm D15B and a complete 97 GS Integra. Does anyone know what EXACTLY I'll need from the civic to swap the D to the teg? I can't find a write up or much other info on this...
Old Nov 20, 2010 | 06:26 PM
Kseries_em's Avatar
you gonna need to convert the motor to obdII and get an obdII ecu
Old Nov 20, 2010 | 06:29 PM
Why? Wouldn't I just get an obd2 to obd1 jumper harness for the P28 ecu I have now? The Z6 wiring harness I'm using right now will plug right into the shock tower plug, but since I want vtec, should I swap the shock harness from the Civic to the Teg? I'll be putting the B18 in the Civic so...
Old Nov 20, 2010 | 06:40 PM
Kseries_em's Avatar
yeah you should be able to just swap the shock harness
Old Nov 21, 2010 | 10:00 AM
fv8s's Avatar
Such a dumb idea. Its like having sex with a midget.. you can do it, but nobody will like you for it.
Old Nov 21, 2010 | 12:03 PM
Kseries_em's Avatar
x2
Old Nov 21, 2010 | 02:51 PM
Didn't ask if was a good idea or not, but thanks. And don't blame me for it, honda did it first.
Old Nov 21, 2010 | 03:14 PM
mouab18c1's Avatar
Free Integra, cant complain
Old Nov 22, 2010 | 06:40 AM
Community Builder
It's a better idea than this ^^^ post Most people do this as a TEMPORARY means of transportation while the car's real engine is worked on. I doubt anyone would do this as a permanent solution, unless someone just wanted the fuel economy but the looks and conveniences of the Integra.
Old Nov 22, 2010 | 08:52 AM
I'm doing it as a permanent solution. It's only 10 less hp... That'll get made up for in the weight reduction.
Old Nov 22, 2010 | 08:55 AM
DBiNfEcTeD*'s Avatar
^maybe 10hp less...but wat bout the torque??? ever think of that......
"there's no replacement for displacement"
Old Nov 22, 2010 | 08:56 AM
2LEM1's Avatar
I like to party
Community Builder
Complete LS swaps are like 800 bux installed. Jesus, get a job.
lazyxmofo
Mar 31, 2008 09:21 PM
gsrcandyman
Sep 30, 2007 07:43 PM
B18CYAAA
Jul 31, 2007 04:17 AM
error
Aug 11, 2005 05:12 PM
mafia
Acura TSX
10
Jul 9, 2005 04:42 AM
