Suspension & Brakes Theory, alignment, spring rates....
Replace seals when changing axles?
Old Aug 30, 2006 | 09:15 AM
DANgerous's Avatar
Default Replace seals when changing axles?
Yes, I need to replace my axles on my 96 civic hatchback and I did a search and found some very interesting info and a thread that I will use to do the whole process, but I got off the phone with an auto mechanic and he suggested having the seals replaced where the axles go into the transmission housing area. I was not aware that these seals should be replaced. Has anyone done this or think that it is something that should be done?
Old Aug 30, 2006 | 09:26 AM
SilverDc2's Avatar
Default Re: Replace seals when changing axles? (DANgerous)
it is possible to do it with the axles out. just get some thin pryers or a flathead,
Old Aug 30, 2006 | 09:33 AM
DANgerous's Avatar
Default Re: Replace seals when changing axles? (SilverDc2)
Is it necessary though? Basically, is this part of a normal axle replacement process that Midas, Les Schwab, etc. would do?
Old Aug 30, 2006 | 10:16 AM
SilverDc2's Avatar
i dont think so, its more if its worn or torn or leaking replace it, its only 2-3 bucks so i would just do it.
rzstr
Honda Civic (2001 - 2005)
15
Oct 31, 2011 07:42 PM
VDM_DC2
Suspension & Brakes
11
Oct 28, 2009 12:28 PM
smoovekriminal
Sep 25, 2007 07:50 PM
dunkd
Jan 3, 2004 06:45 PM
