1991 Accord: starts but then dies
Old Aug 30, 2006 | 08:42 AM
src176's Avatar
Default 1991 Accord: starts but then dies
my accord starts fine, but at soon as I let go of the key it dies. i can actually hold the key in a position just before the stater engages and drive the car holding the key in just that position...that's how I limped it home.
Is this a problem with the key barrel? Is it a switch in the column?
Old Aug 30, 2006 | 12:34 PM
Perfectionist's Avatar
Default Re: 1991 Accord: starts but then dies (src176)
Ignition switch. You don't have to replace the cylinder, just the switch part behind it. After you get the column shroud off, there are typically 2 screws that hold the switch assembly to the key cylinder.
Old Aug 30, 2006 | 05:03 PM
Honda-Master's Avatar
call the dealer and get the electrical portion of the ignition switch ,,around 60 dollars ,,,,,,
then do as pefectionist adviced ,, it is very easy to replace
Old Aug 31, 2006 | 06:43 AM
sgrahame21's Avatar
Default Re: 1991 Accord: starts but then dies (Perfectionist)
Interesting...son was driving his 95 accord LX home and both the tack and speedometer dropped to "0" but the engine did not falter. He got it home and turned off the engine and tried to start it again. The engine would kick over like it started then immediately turn off. I checked the wiring inside and out plus fuses and everything looked good. Verified all his electrical was was working inside and it all worked. Also monitored all the indicators on the his instrument panel during intial start up, you know oil, brake, ect, they come on and go off as soon as the engine starts like normal. Wonder if I have the same problem with the ignition switch but I am starting to think ECU may be a player here also. Any Ideas??
Old Aug 31, 2006 | 07:53 AM
londonsupra's Avatar
^ you have the excat same problem.. take your car to honda they should fix it for free as there was a recall on your ignition switch.
clifftbrd
Apr 26, 2014 10:50 AM
chaza
Jul 21, 2012 06:45 PM
singlecamsaint
Apr 14, 2011 07:36 PM
Rushesright
May 20, 2008 07:31 PM
bluesguitarguy72
May 9, 2007 11:22 AM
