HELP! '90 CRX w/ B16 won't start
Old Aug 30, 2006 | 08:15 AM
Bump's Avatar
Default HELP! '90 CRX w/ B16 won't start
on monday i took my crx to a shop to get it tuned with the hondata s200. i have a b16a2 and whats done to the car is all bolt ons, I/H/E/IM. the shop calls me and says the car has died and wont start back up while on the dyno. so i go up there to the shop and check it out. everything checks out electrical wise, spark plugs, injectors, ecu is sending a signal, the car just will not turn over, but it wants to. the guy workin on the car says it could be the fuel pump. the crx is still on its original pump. could this maybe be whats wrong? what else could be the problem, any ideas?
also, the fuel filter didnt let out any fuel when the pressure relief valve was opened.
thanks for all the help in advance
Old Aug 30, 2006 | 11:32 AM
Stroker
Guest
Posts: n/a
Default Re: HELP! '90 CRX w/ B16 won't start (Bump)
can you hear the fuel pump cycle when you turn the ignition on?
Old Aug 30, 2006 | 01:44 PM
Bump's Avatar
Default Re: HELP! '90 CRX w/ B16 won't start (Stroker)
i did try and listen for that i dont think i heard it turn on b/c i do kno what it sound slike when it turns on, but thing is it was kind of loud in the shop, so im not absolutely sure
Old Aug 30, 2006 | 04:50 PM
Stroker
Guest
Posts: n/a
go tuen on anyother car in the shop and you will hear a humm if there is no hum then there is no fuel pump running. Dont start the car just turn it on
hasty91ef
Mar 10, 2013 05:09 PM
ih8sndq
Mar 9, 2010 09:02 PM
smokincrxwannabe
Mar 14, 2008 06:24 PM
88hondaef
Aug 28, 2006 10:58 AM
FUP23
Jun 30, 2002 01:57 PM
