HELP ASAP
unscrew the drain bolt on the bottom of the radiator. replace screw. fill. then run the car with the cap off to get all the air out of the system and then put the cap back on
1.) Open radiator cap
2.) Unscrew drain plug at the bottom of the radiator, drain fluid
3.) Reinstall drain plug, fill radiator and overflow, reinstall rad. cap
4.) Loosen bleed screw near thermostat
5.) Start car, let it warm up (upper rad. hose will be hot)
6.) Wait until no more air comes out of the bleed screw
7.) Tighten bleed screw, done!
Just some advice too, go down to your local auto parts store and pick up a Haynes manual, has all this kind of stuff in it
