fs.gsr low compression pistons 81mm standard je/srp ring set
Old Aug 30, 2006 | 05:22 AM
slowdaintegra's Avatar
Default fs.gsr low compression pistons 81mm standard je/srp ring set
sold sold sold
gsr low compression pistons 81mm standard je/srp just pistons and wrist pins
brand new je piston rings
275 for everything if you get you get the old set of rings new set of rings and the wrist pin clips
pistons used for 500 miles had pistons checked out by don at DFE and he said they were good
Modified by slowdaintegra at 10:07 AM 9/8/2006
Modified by slowdaintegra at 11:30 AM 9/27/2006
Modified by slowdaintegra at 8:24 PM 10/3/2006
Modified by slowdaintegra at 4:15 PM 10/17/2006
Modified by slowdaintegra at 4:19 PM 10/17/2006
Modified by slowdaintegra at 7:42 PM 11/6/2006
Old Aug 31, 2006 | 07:02 AM
Default Re: fs.gsr low compression pistons 81mm standard je/srp ring set (slowdaintegra)
bump
Old Sep 1, 2006 | 08:10 AM
bump
Old Sep 4, 2006 | 04:14 AM
bump
Old Sep 6, 2006 | 06:45 AM
bump
Old Sep 7, 2006 | 11:51 AM
bump
Old Sep 9, 2006 | 07:23 AM
bump
Old Sep 10, 2006 | 10:57 AM
bump
Old Sep 12, 2006 | 12:32 PM
bump
Old Sep 15, 2006 | 04:07 PM
bump
Old Sep 18, 2006 | 08:55 PM
bump
Old Sep 22, 2006 | 05:49 AM
someone buy theese they are good pistons
Old Sep 24, 2006 | 09:27 AM
bump
Old Sep 27, 2006 | 07:30 AM
BUMP MAKE OFFER
Old Oct 3, 2006 | 04:23 PM
bump
Old Oct 8, 2006 | 03:32 PM
bump
Old Oct 12, 2006 | 10:40 AM
up
Old Oct 13, 2006 | 03:32 AM
bump
Old Oct 16, 2006 | 03:25 AM
bump
Old Oct 19, 2006 | 05:19 AM
bump
Old Oct 19, 2006 | 07:55 AM
RICHBCM's Avatar
bump
Old Oct 20, 2006 | 03:14 PM
EF9-CIVIC's Avatar
Default Re: fs.gsr low compression pistons 81mm standard je/srp ring set (RICHBCM)
whats the compression on a stock ls. also are the pistons je or srp.
Old Oct 21, 2006 | 01:29 PM
Default Re: fs.gsr low compression pistons 81mm standard je/srp ring set (EF9-CIVIC)
pmed
Old Oct 23, 2006 | 02:29 PM
bump
Old Oct 25, 2006 | 05:03 PM
bump
