Fixing my rust soon
Im about to start fixing the rust on my crx 1/4's soon. I plan to go cut out patch panel out of a junkyard car. ok i need some tips, when im ready to weld in the patch panel what should i do to prep the panel? after everything is welded in what should to prevent more rust?
I plan to use por15, how exaclty does it work? after i grind down all the welds do i apply it and spread filler over it, smooth things out and primer?
if someone could give me step by step, that would be great
https://honda-tech.com/zerothread?id=476935
https://honda-tech.com/zerothread?id=376870
https://honda-tech.com/zerothread?id=542359
FAQ = FTW
I personally leave that stuff for the body shop.
FAQ = FTW
i was told by my friends dad who does alot of body work, that the primer keeps the rust out, you could prolly get some rustoleum primer or something like that.
but its that bad you need to cut it out? i just used a dremel and got rid of it and bondo'd it, and if it was an actual hole the bondo comes with little metal sheets that stick to the area for you to bondo onto
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baconcrx »</TD></TR><TR><TD CLASS="quote">i was told by my friends dad who does alot of body work, that the primer keeps the rust out, you could prolly get some rustoleum primer or something like that.
but its that bad you need to cut it out? i just used a dremel and got rid of it and bondo'd it, and if it was an actual hole the bondo comes with little metal sheets that stick to the area for you to bondo onto</TD></TR></TABLE>
That's the ghetto way of fixing it. The right way is cut and paste a new sheet of metal formed to fit.
Por15 is rust proof primer. Works like wonders.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX MASE »</TD></TR><TR><TD CLASS="quote">Im about to start fixing the rust on my crx 1/4's soon. I plan to go cut out patch panel out of a junkyard car.</TD></TR></TABLE>
Right there is a bad idea. junkyard cars usually arn't in the best of shape. Every crx i've seen in a yard or even on the street has the slightest bit of rust. better off getting an aftermarket piece that is brand new and has NO rust. this place supposedly sells rear qusters. Contact them: http://www.pacollision.com/
Modified by ICeDoUt at 10:59 AM 8/30/2006
Whoa check out that website. $50 for a rear 1/4 wheel well liner? FTW! And yes POR-15 kicks *** you just have to make sure you get it EVERYWHERE you don't want rust. How does it work? expletive if I know, read the directions before you use it!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX MASE »</TD></TR><TR><TD CLASS="quote">i dont see anything on that website for crx's (patch panels)</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civhatch90 »</TD></TR><TR><TD CLASS="quote">i need them too, and dont see them either</TD></TR></TABLE>
Contact them. I am sure they can hook it up with a price
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ICeDoUt »</TD></TR><TR><TD CLASS="quote">
Modified by ICeDoUt at 10:59 AM 8/30/2006</TD></TR></TABLE>
That's because you're from PA. There are actually rust free 1/4's on CRXs out here on the salt-free west coast.
This is an East Coast conversation see your West Coast *** on out of it
no need to rub it in. Believe me i wish there were such a thing over here
Vagitarian
Paint and Body
12
May 5, 2014 06:43 PM
AgentJam
Dec 23, 2003 01:08 PM
serious
Jul 2, 2002 10:22 AM
