Questions about an itegra.
I found this integra in a boneyard today. Not sure what year as I do not know enough to tell them apart by looking at them. I could not look in the door.
The car has a cable operated 5 speed trans with a b18a non vtec motor. and rear disc brakes.
Are these the rear disc brakes that swap to the civics?
Whats the motor worth?
Trans?
Was thinking of buying it to part it out.
Trans?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E.Honda »</TD></TR><TR><TD CLASS="quote">I found this integra in a boneyard today. Not sure what year as I do not know enough to tell them apart by looking at them. I could not look in the door.
Trans?
It is a DA chassis. If it's a 90-91, its OBD0, 92-93 is an OBD1 car. You might be able to get $500 for the motor/ tranny if it runs perfect. A couple hundred for the brakes at most, the would directly swap onto EF civics as far as I know. Someone correct me on this if I am wrong.
Trans?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shutupnskate »</TD></TR><TR><TD CLASS="quote">
I agree with this guy. $500 for the motor/tranny sounds about right, however you're taking chances if you're not sure if it even runs. Could have blown HG, rings, or whatever. Im sure the rear discs will swap into an EF, so you can certainly sell those off. Overall, if you get the chassis for really cheap, you can make some money off of it. But it might be more work than it's worth.
</TD></TR></TABLE>I agree with this guy. $500 for the motor/tranny sounds about right, however you're taking chances if you're not sure if it even runs. Could have blown HG, rings, or whatever. Im sure the rear discs will swap into an EF, so you can certainly sell those off. Overall, if you get the chassis for really cheap, you can make some money off of it. But it might be more work than it's worth.
hondaOchibi7
11
Dec 15, 2010 01:22 PM
trip-doh
12
Jan 19, 2008 10:19 AM
jxhxb
Oct 6, 2007 03:53 PM
**DOHC HaTcH**
Mar 21, 2007 12:48 PM
