Question about install of dvd player in for f150.
Old Aug 29, 2006 | 11:16 PM
E.Honda's Avatar
Default Question about install of dvd player in for f150.
I have a 98 for f150. I picked up this dvd player.
The dash has a double din size opening as well.
I just dont see any way to attatch this head unit in that dash design.
Surely this is not a custom install job.
Anyone have knowledge of this application or know of an install kit?
Thanks
Old Aug 30, 2006 | 04:37 AM
vicn77's Avatar
Default Re: Question about install of dvd player in for f150. (E.Honda)
I believe Metra has a double din kit they make that will fit your car, I'll see if I can find the model number when I go to work later on today.
Old Aug 30, 2006 | 05:34 AM
audioroach's Avatar
you are going to have to customize it to fit. yes the opening is quite close to 2 din size. Did you buy it new? if so you should have the 'cage' that the radio locks into. You secure the cage to the sub dash- your trim will fit over it. You may have to mold/modify the dash trim if you want an 'oem' look to it.
Old Aug 30, 2006 | 01:35 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Question about install of dvd player in for f150. (audioroach)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by audioroach &raquo;</TD></TR><TR><TD CLASS="quote">you are going to have to customize it to fit. yes the opening is quite close to 2 din size. Did you buy it new? if so you should have the 'cage' that the radio locks into. You secure the cage to the sub dash- your trim will fit over it. You may have to mold/modify the dash trim if you want an 'oem' look to it.</TD></TR></TABLE>
ditto that
Old Aug 30, 2006 | 03:57 PM
fcm's Avatar
fcm
Old Fart
This may help... http://www.scosche.com/media/D...p.pdf 94
Old Aug 30, 2006 | 05:03 PM
JSPECSIR's Avatar
Default Re: Question about install of dvd player in for f150. (fcm)
put that radio in the radio hole to the depth it needs to be, take backstraps and bend accordingly from the iso holes on the side of the radio to the oem plastic frame arond the radio. take a scew(&lt;no r) driver and fasten the back straps to the radio with the iso screws, then take short screws and run through the backstraps into the oem plastic frame. put you oem trim/ dash vent panel back on. then take the trim ring that comes with the radio and grind on bench grinder until it fits to fill the gap between the new radio face and the oem trim. we have done NUMEROUS double din screens in your body style f150 at my work, and they look damn good in there. i hope this helps, good luck.
Old Aug 30, 2006 | 06:43 PM
E.Honda's Avatar
Default Re: Question about install of dvd player in for f150. (JSPECSIR)
I got it installed tonight.....There is no kit for this application so it was a custom install.....It turned out good. Thanks guys.
Wkz1gg0a
Honda CR-V & Element
May 4, 2011 02:30 AM
gooberguy
Audio / Security / Video
16
Aug 27, 2009 07:23 AM
andoxviii
Dec 28, 2008 10:07 PM
thetomshow
Mar 8, 2007 07:02 PM
dazco
Dec 21, 2002 04:39 PM
