what FPR setting
Old Apr 27, 2002 | 03:38 PM
LB CRX's Avatar
Default what FPR setting
i just slapped on a B&M fuel pressure regulator and i just needed some input at where my setting should be. my mods include.....
b16a5
4-1 type R headers
iceman cold air intake
head is slightly milled
civic type R intake cam
gsr exhaust cam
2.5" piping
jg cam gears set at 4 degress i think
type r manifold
jg throttle body
my stock pressure was at 29...and i set it to 32 not knowing where it should be. i figure that i need to run a little richer, but i need more opinions. TIA
Old Apr 29, 2002 | 07:56 AM
crxman00's Avatar
Default Re: what FPR setting (LB CRX)
I have the exact same setup . Your stock fuel pressure for a B16a(any gen) should be 37psi. But my Intake is set to +2 and my exhaust is +1. But I have my fuel around 45 psi @ idle and around 48 psi WOT.
Old Apr 29, 2002 | 09:23 AM
88_SC_CRX_Si's Avatar
New User
Watching the color of your plugs, will tell you which way to go. Start around where it's mentioned above at, and go from there. Might get some some Anti-Seize, to put on the plugs. That way you don't have to worry about pulling the the threads out of the head, along with the plug when it's hot...
Old Apr 29, 2002 | 09:13 PM
LB CRX's Avatar
Default huh?
my stock pressure was at 29 psi....what does that mean? im using the gsr fuel rail. should i get something checked out? sorry bout this....im still in the learning process
TIA
Old Apr 30, 2002 | 04:00 AM
Todd Reid's Avatar
Default Re: huh? (LB CRX)
are you checking it with the vacuum line disconnected?
i have an LS, not a VTEC motor, but my stock pressure was 37 - 40 psi if i remember (vac line disconnected).
Old Apr 30, 2002 | 06:25 AM
AussieK24's Avatar
Default Re: huh? (Todd Reid)
Yeah, I found 40 psi a good place to start (Vacuum disconnected).
It varies between different applications, just like timing.
jaref9
Jun 27, 2009 11:35 AM
C4wrx
Apr 23, 2002 06:40 AM
macdaddy
Mar 20, 2002 06:23 PM
NeXtLeVeL_TyPe_R
Nov 6, 2001 07:15 PM
sicivic
Sep 22, 2001 05:37 PM
