Clutch Question?????
Old Aug 29, 2006 | 11:08 PM
1SiC 3DR's Avatar
Default Clutch Question?????
i have searched so please dont bitch, a friend of mine has a 1990 Crx Si w/a 1991 B18A1 w/a YS1 trans we are having trouble getting the right clutch for this - any help or advice would be greatly - i am not really knowledgable on cable trans and there differences - thanks for veiwing and keep me to the top i need answers
Old Aug 29, 2006 | 11:27 PM
1SiC 3DR's Avatar
Default Re: Clutch Question????? (B162XLR8)
also the factory LS clutch disc will not line up, the spline on the trans is bigger then the one on the disc itself, there was no clutch with the car when he purchased the car also
Old Aug 30, 2006 | 05:52 AM
dbsharp's Avatar
maby get a clutch disk from what ever that tranny come from and use the pressureplate and flywheel for your motor? if the disk fits id just do that.
Old Aug 30, 2006 | 11:17 AM
1SiC 3DR's Avatar
Default Re: Clutch Question????? (dbsharp)
well see that is one problem i'm running into i was told it was a factory LS trans but every LS clutch disc we use never works, so i read the trans code number which is YS1 and i always thought that was 88-91 or 90-93 JDM B16A cable trans and i'm wondering if the input shaft is bigger than the factory LS trans, but just a thought - and i do appreciate the input
Old Aug 30, 2006 | 11:14 PM
1SiC 3DR's Avatar
no help for me i see
Old Aug 31, 2006 | 02:20 PM
FaceTuned's Avatar
look your problem is that you dont know the year of the tranny you either have 90-91 or 92-93 ls tranny you said you have more splines i think 24 or 25 use a clutch from a 94-01 integra it works fine 90-91 is the smaller spline if you have any other problems your doing something wrong.
Old Aug 31, 2006 | 02:51 PM
1SiC 3DR's Avatar
that is exactly what the problem was, thank you for your input you are greatly appreciated
Old Sep 1, 2006 | 02:21 PM
FaceTuned's Avatar
im glad i could help you out!
VTEC_Honda
Mar 7, 2010 12:06 PM
EGandDArida
Jul 16, 2009 10:42 AM
rewerbcrx
10
Sep 1, 2007 06:38 AM
synner
Aug 12, 2007 08:08 PM
Go n 4 10s
Mar 22, 2006 01:55 PM
