which ECu is best for b16a
Old Aug 29, 2006 | 10:00 PM
salman's Avatar
Default which ECu is best for b16a
Hi all,
I have a B16A which i have converted to OBD1 and now i am Using it on P30 EDM.
I want to ask which ECu will be batter to use,
P30 EDM,
PR3
I have them both,
Thanks in advance,
Old Aug 29, 2006 | 10:06 PM
Deetz's Avatar
Crazy Honda Guy
Either one can be programmed with crome, hondata, or uberdata...it makes no difference.
Old Aug 29, 2006 | 10:18 PM
salman's Avatar
I forgot to mention that i also have chiped PO6 with VTEC,
Old Aug 30, 2006 | 12:49 AM
philkehn's Avatar
well i know the the pr3 has a higher redline limit as well as a vtec that kicks in sooner then the pw0, i think the p30 is just like a pr3 for obd1?
Old Aug 30, 2006 | 02:04 AM
salman's Avatar
Default Re: (philkehn)
In a Pr3 that Vtec kicks in at 6200 while at P30 the vtec is at 5500,
Old Aug 30, 2006 | 04:05 AM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philkehn &raquo;</TD></TR><TR><TD CLASS="quote">i think the p30 is just like a pr3 for obd1?</TD></TR></TABLE>
Yes and no. An OBDI PR3 actually exists (1992-1993 Integra XSi).
Old Aug 30, 2006 | 04:14 AM
salman's Avatar
Default Re: (StorminMatt)
soo its batter or not.
Old Aug 30, 2006 | 06:00 AM
Deetz's Avatar
Crazy Honda Guy
Default Re: (salman)
obd1 pr3 and p30 are the same ecu, i know, i have both
Old Aug 30, 2006 | 08:40 PM
salman's Avatar
I dont think they are same, P30 fueling is richer then PR3, adn vtec points are also diffrent,
Old Aug 30, 2006 | 09:17 PM
Deetz's Avatar
Crazy Honda Guy
The run the same engine from the same years......just come out of different chassis.
Old Aug 30, 2006 | 11:53 PM
salman's Avatar
Default Re: (Deetz)
As for me i have a B16a which have pr3 obd0 with it,
I converted it into obd1 and i was using p30 on it,
I have just exchanged it with obd1 pr3 from a friend,
My car is a Ef3 civic hatch, with I/E
Old Aug 31, 2006 | 07:24 AM
dr@ke's Avatar
i have a p28 ecu is this a good ecu for a b16a2 our would a p30 be better?
Old Aug 31, 2006 | 02:45 PM
salman's Avatar
Default Re: (dr@ke)
p30 is batter then any Sohc vtec ecu, and also Dohc vtec,
Reffering to the one with out IAB"S
I am running PR3, i am feel that the voice of the vtec is a low as it was in p30,
Is it really happening or its just my imagination,
Old Aug 31, 2006 | 07:37 PM
philkehn's Avatar
Default Re: (dr@ke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr@ke &raquo;</TD></TR><TR><TD CLASS="quote">i have a p28 ecu is this a good ecu for a b16a2 our would a p30 be better?
Yea a p28 is for a z6/y8 which are sohc vtec you have a dohc vtec
Old Aug 31, 2006 | 10:33 PM
michael O's Avatar
Default Re: (Deetz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz &raquo;</TD></TR><TR><TD CLASS="quote">Either one can be programmed with crome, hondata, or uberdata...it makes no difference.</TD></TR></TABLE>
that's definately true.
Old Sep 1, 2006 | 07:37 AM
dr@ke's Avatar
so am i losing horse power with the p28?
Old Sep 1, 2006 | 10:58 AM
salman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salman &raquo;</TD></TR><TR><TD CLASS="quote">I am running PR3, i am feel that the voice of the vtec is a low as it was in p30,</TD></TR></TABLE>
Old Sep 1, 2006 | 02:57 PM
Default Re: (dr@ke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr@ke &raquo;</TD></TR><TR><TD CLASS="quote">so am i losing horse power with the p28?</TD></TR></TABLE>
most likely yes. but yu can get it chipped to run with the b16a
fuel and everything is different for z6 compared to b16
Old Sep 2, 2006 | 11:24 PM
salman's Avatar
will check to confurm more today what which ECu is a batter
Old Sep 2, 2006 | 11:39 PM
SaturdayNightWrist's Avatar
Appears to be duplicate account.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salman &raquo;</TD></TR><TR><TD CLASS="quote">p30 is batter then any Sohc vtec ecu, and also Dohc vtec,
what in the hell is your infatuation with the "sound of vtec"? i swear every post youre saying something like "stock gsr cams willm ake my vtec sound different than stock b16 cams."
1. get p28 or basically any obd1 ecu
2. identify the 26 pin chip specified on the crome site
3. grow some nuts
4. get a low voltage iron and a solder sucker
5. go to town until it falls out.
6. insert 26 pin zif socket
7. call tuner and say "hey i have a stock obd1 b16, need a crome chip for it, its stock, i just want a 5100 vtec, 8200rev limit, no knock and no o2. oh yea, try to get me as closeto about 12:1 straight across as you can guesstimate by teh info im giving you. can i pick you up anything form taco bell"
8 insert said chip into said zif socket
9. enjoy "the voice of vtec"
808sleeperhatch
Jan 12, 2011 07:26 AM
918eg
Sep 9, 2008 09:46 AM
D Grade
12
Sep 10, 2005 07:00 PM
90HFCrX
Jul 16, 2004 10:09 AM
casper625
Nov 24, 2003 08:04 PM
