dyno results
Old Aug 29, 2006 | 08:48 PM
DARKTEG_'s Avatar
Default dyno results
146 whp 123 torque
and this is what i have done "Under The Hood":
b18b obd1
Act stage 4 clutch, pressure plate, and release bearing
AEM Cold air intake
AEM fuel rail
AEM tru time pulleys
B&M fuel pressure regulater, with gauge
Crower stage 1 cams
Crome performance chip
DC Sports 4 2 1 one piece header
Golden eagle adjustable cam gears
GSR obd2 injectors
GSR transmission Phantom Grip LSD with LS 5th gear
Mr. Gasket distributor cap and rotor button
Nopi brand - lightweight flywheel
Skunk 2 intake manifold
Unorthadox Crank pulley
Modified by gonk_1 at 7:05 AM 8/30/2006
Old Aug 29, 2006 | 09:15 PM
onepoint6i's Avatar
Default Re: dyno results (gonk_1)
not bad, considering what it is..
Old Aug 29, 2006 | 09:29 PM
Spoon*EK9's Avatar
I don't keep up on modded LS dyno numbers, but, it seems a little low considering the mods. Perhaps it's untuned since the cam install?
Eh, I could be wrong. lol...Just seems low to me. I have a 97 JDM ITR motor in my EK, completely stock except for the 4-1 DC race header. I had it tuned using my P28 with Crome, and got 190 whp, and 133wtq. I must say the tuner is pretty kick ***
Old Aug 30, 2006 | 06:06 AM
DARKTEG_'s Avatar
Default Re: (209SpoonEK9)
it was just tuned last night.... he said if i wasn't running a stock exhaust i would've been over 150
Old Aug 30, 2006 | 10:14 AM
Spoon*EK9's Avatar
OIC. Yeah, upgrading the exhaust would help ALOT. What did u tune it with?
Old Aug 30, 2006 | 01:44 PM
DARKTEG_'s Avatar
it was tuned on a dynojet using a crome performance chip and ajusted the cam gears -4 exhaust side, and -1 intake side and the timing from 16 to 15
Old Aug 30, 2006 | 03:13 PM
TwoRedEGgs's Avatar
Default Re: (gonk_1)
Thats pretty good considering most b18b's with basic bolt on lay down high 120's- 30's . If you still running stock cat and exhaust there is allot left.
Old Aug 31, 2006 | 08:20 AM
DARKTEG_'s Avatar
Default Re: (TwoRedEGgs)
ya the dyno guy said if i change my exhaust i could get over 150 at the wheels no problem...stock exhaust is a problem at this point.
DARKTEG_
Sep 3, 2006 08:30 PM
DARKTEG_
Aug 30, 2006 06:39 AM
DARKTEG_
Aug 24, 2006 09:48 PM
DARKTEG_
Aug 24, 2006 04:17 PM
