dyno results
146 whp 123 torque
and this is what i have done "Under The Hood":
b18b obd1
Act stage 4 clutch, pressure plate, and release bearing
AEM Cold air intake
AEM fuel rail
AEM tru time pulleys
B&M fuel pressure regulater, with gauge
Crower stage 1 cams
Chrome Perfromance Chip
DC Sports 4 2 1 one piece header
Golden eagle adjustable cam gears
GSR obd2 injectors
GSR transmission Phantom Grip LSD with LS 5th gear
Mr. Gasket distributor cap and rotor button
Nopi brand - lightweight flywheel
Skunk 2 intake manifold
Unorthadox Crank pulley
Modified by gonk_1 at 7:00 AM 8/30/2006
b18b obd1
AEM Cold air intake
AEM fuel rail
Crower stage 1 cams
GSR obd2 injectors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleeper Style »</TD></TR><TR><TD CLASS="quote">What kind of dyno?
Numbers seem kind of high for those mods. Are the cam gears adjusted at all?</TD></TR></TABLE>
I can't imagine w/ Intake, IM, H, E, cam gears, pulleys, etc he would be any less. I would say that's probably about right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by It’s BOLO!! »</TD></TR><TR><TD CLASS="quote">LEWIE, i see you joined the squad
.brian. said he was giving out free reach arounds.
</TD></TR></TABLE>.brian. said he was giving out free reach arounds.
Good numbers
they seem right.......
I had a b18b with j's cf intake, skunk2 im, fpr, head was port n polished with crane springs n retainers, crane stg2 cams, tuned skunk 2 cam gears, aem pulleys, dc jdm 4-1 header, 2.5 full exhaust, uberdata chip'd n tuned ecu, stock drivetrain
I pulled 143 whp and 126 trq
peak power was made at 7400 rpm's
they seem right.......I had a b18b with j's cf intake, skunk2 im, fpr, head was port n polished with crane springs n retainers, crane stg2 cams, tuned skunk 2 cam gears, aem pulleys, dc jdm 4-1 header, 2.5 full exhaust, uberdata chip'd n tuned ecu, stock drivetrain
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegnation22 »</TD></TR><TR><TD CLASS="quote">this is wrong, must be on a dyno jet to the wheels those are high numbers, maybe at the crank r the fly</TD></TR></TABLE>
thats right man. because all those mods would only give 4 flywheel hp
Modified by STD ****** at 7:44 AM 9/2/2006
Once you start upgrading the valvetrain and adding cams along with bolt-ons to these motors you will see numbers like this....... now if you increase the compression on these motors with some beefy pistons they will really come to life... do a search, I've seen numbers here on H-T 175 and up on all motor LS apps
Like I said be proud Gonk those are decent LS numbers
146 is pretty decent for the things you got, but IMO I think you spent some money on thing you really don't need unless you were turbo....LS-T's are wicked sweet!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_bones »</TD></TR><TR><TD CLASS="quote">146 is pretty decent for the things you got, but IMO I think you spent some money on thing you really don't need unless you were turbo....LS-T's are wicked sweet!
highlight those things in his setup...only waste of money i saw...and this would be for turbo or not...was the fuel rail
</TD></TR></TABLE>highlight those things in his setup...only waste of money i saw...and this would be for turbo or not...was the fuel rail
