Check engine light: Code P1457
As stated throwing a code p1457.
From what I have got so far its a emissions code, which is unable to pull vacuum in tank.
Which part is it talking about?
What parts do I need to fix it?
How hard is it to fix?
TIA!
TIA!
* EVAP canister is leaking, damaged or full of water
* EVAP canister purge line is loose, damaged or blocked
* EVAP two-way valve or ORVR vent shut valve is damaged
* EVAP fuel tank vapor control valve is damaged or has failed
* PCM has failed
Detected (Canister Area) Cold startup completed (IAT sensor signal from 32-86�F at engine startup), vehicle driven at over 5 mph for over 2 minutes, then with ECT sensor signal more than 154�F and the EVAP Control and Vent solenoids enabled, the PCM detected the fuel tank pressure was incorrect due to a leak in the canister area during the Leak Test.
This code sets in 2 Trip(s).
* PCM has failed
depends on how long it takes to diagnose it. usually they will charge you to pull the code. then diagnose it, it should take a good tech less than an hour to find out where its leaking
1998_4dr_gsr
Oct 27, 2006 03:21 PM
vtecdc2
Jul 16, 2002 08:32 AM
