Can I use my Z6 head studs for my mini me swap???
Old Aug 29, 2006 | 06:42 PM
Xemu's Avatar
Default Can I use my Z6 head studs for my mini me swap???
D15B2 block with a D16Z6 head,can I use the D16Z6 head bolts??? Thanks
Old Aug 29, 2006 | 09:06 PM
Xemu's Avatar
Default Re: Can I use my Z6 head studs for my mini me swap??? (Xemu)
Somebody knows this???
Old Aug 29, 2006 | 10:36 PM
93formula's Avatar
you can use a d16 head on a d15? theres something i didnt know.
edit: apparantly you can, cool. anyways i would suggest you look up the part numbers for the d16 and the d15 head bolts, if there the same that would answer your question.
Old Aug 29, 2006 | 10:43 PM
Xemu's Avatar
Default Re: Can I use my Z6 head studs for my mini me swap??? (93formula)
Yeah I already knew that......what I need to know is if I can use the studs from the Z6??? Anybody???
Old Aug 29, 2006 | 10:46 PM
93formula's Avatar
does arp list them as the same part numbers?
Old Aug 29, 2006 | 11:11 PM
Xemu's Avatar
Ideally I would like a set of ARP head studs used or new if anyone knows anybody who has some they want to sell please let me know.The ARP website does not list head studs for D15B2 just a Y8 and a Z6.
Old Aug 29, 2006 | 11:16 PM
93formula's Avatar
then i would use the z6 ones.
Old Aug 30, 2006 | 02:44 PM
Xemu's Avatar
My d15b2 bolts fit and these only have 59,000 miles on them compared to the d16z6 ones that have over 100,000,can I use the d15b2 bolts for my z6 head??? Somebody help me out here.I know it would be best to buy ARP head studs but funds are getting a little outta hand so I'd like to save some $$$$ where ever I could. HELP,HELP,HELP!!!!!
Old Aug 30, 2006 | 03:09 PM
Brick Top's Avatar
1.6 head on 1.5 block. use 88-95 civic head bolts. 96 and up are too short. so yes the d15 bolts will work fine. same with the z6s. compare the lengths for yourself.
Old Aug 30, 2006 | 03:34 PM
Xemu's Avatar
Default Re: (brick top)
Thank you.
Old Aug 30, 2006 | 08:39 PM
93formula's Avatar
Default Re: (Xemu)
personally i wouldnt skimp out on head bolts
Old Aug 30, 2006 | 09:02 PM
1990si's Avatar
Default Re: (93formula)
on my y8 mini me swap i used all y8 bolts exccept the one near the solenoid i had to use an a6 bolt because on the a6 head its a different size near that part of the head. its hard to explain.
knightsef-eg
Dec 3, 2009 10:09 AM
wfocrx
Apr 6, 2007 01:34 AM
Jizzmaster Zero
Sep 6, 2005 10:47 AM
jdmstreethatch
Aug 17, 2005 08:01 AM
ghettocrxsi
11
Apr 23, 2003 03:41 PM
