New to the crx and having a problem!!
Old Aug 29, 2006 | 05:12 PM
90crxdriver's Avatar
Default New to the crx and having a problem!!
Ok here I go. I got te CRX about 7 weeks ago and its been acting up. 90% of the time it starts and runs fine. But other times mostlly after its been runing it will crank and start but then stalls. If I try to crank it it jus turns over and woun't start. If its left alone for a while it will most of the time start up and be fine.
I know it has spark, I know it has fuel presure.
I think the injectors arn't firing.
I changed the injector resister modle and same problem.
I'm going to change the o2 senser ASAP
motor Mods to car are
cold air intake with new filter
4-2-1 header
catback exhaust
thats it
Please help I really wan't to make it to NOPI this year.
Old Aug 29, 2006 | 05:23 PM
eda6's Avatar
Default Re: New to the crx and having a problem!! (cordiaturboowner)
troubleshoot and pinpoint the problem before you throw parts at it.
i bet if you removed your main relay and desoldered the ckt board, then applied new solder your car would start every time. maybe you have a "dry joint" in your main relay.
Old Aug 29, 2006 | 05:24 PM
jackinthetrunk's Avatar
are you sure you are getting fuel? I had a problem like this and it was my main relay, powers the fuel pump.
Old Aug 29, 2006 | 06:09 PM
89hbcivicguy's Avatar
i had this problem and it was a temp sensor......it wont be your o2 sensor it just measures air and fuel you could unplug it and you car will start ... most likely main relay or temp sensor
Old Aug 29, 2006 | 08:05 PM
Cheeech's Avatar
Default Re: New to the crx and having a problem!! (89hbcivicguy)
Any CEL's? if an injector wasnt firing it would throw a code, happend to me and it was throwing code 16 which is fuel injectors, but i agree with the above comments, could be your main relay.
Old Aug 31, 2006 | 04:24 PM
Default Re: New to the crx and having a problem!! (CheechJDM)
OK I took it for a ride and got back home and cut it off and tryed to restart it and nothing. I didn't hear the fuel pump kick on so I guess its the main relay. Now to try to figure out how to fix if. I got a Honda delership repair book so I should be able to fix it.
thanks
Old Aug 31, 2006 | 04:48 PM
Loserkidwac's Avatar
There are a million posts about fixing main relays, do a google search and I bet you will find the nice one with pictures I used a couple years back with a non-starting car...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89hbcivicguy &raquo;</TD></TR><TR><TD CLASS="quote">i had this problem and it was a temp sensor......it wont be your o2 sensor it just measures air and fuel you could unplug it and you car will start ... most likely main relay or temp sensor
Interesteding which sensor, the one on the head i assume, since i ran my car with the fan switch/temp sensor unpluged for a while...stupid friends saying I didn't need to plug that sensor in Anyways , please elaborate i am interested
Old Aug 31, 2006 | 05:01 PM
eda6's Avatar
Default Re: New to the crx and having a problem!! (Loserkidwac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cordiaturboowner &raquo;</TD></TR><TR><TD CLASS="quote">Now to try to figure out how to fix if.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">
i bet if you removed your main relay and desoldered the ckt board, then applied new solder your car would start every time. maybe you have a "dry joint" in your main relay.</TD></TR></TABLE>
http://www.marklamond.co.uk/te...y.htm
Old Sep 2, 2006 | 01:03 PM
Default Re: New to the crx and having a problem!! (eda6)
Ok thanks for the help eveyone.
I tested the relay and the wiring to it and the relay failed.
I bought a new one and now I'm waiting on it.
thanks
Old Sep 10, 2006 | 11:22 AM
problem fixed it was the main relay
thanks
scottmog
Jun 18, 2009 07:21 AM
Wazup
Dec 1, 2008 02:01 PM
Slow as piss
Oct 4, 2005 02:10 PM
krueger
Apr 29, 2004 07:07 PM
