hit a curb, sliced my tire
Old Aug 29, 2006 | 05:09 PM
gottalovethe4door's Avatar
Default hit a curb, sliced my tire
i know, im an idiot, but i hit the curb... bent the rim a lil bit, but what im realy concerned about is my tire... on the sidewall it took a chunk out... it's still hanging on by a lil thread. Should i cut the chunk off, its a brand new yokahama avs 1000 i dont wanna get rid of it... its getting moved to the back for sure, but is there any thing else i can do????
Old Aug 29, 2006 | 05:13 PM
vtecsi00's Avatar
Default Re: hit a curb, sliced my tire (gottalovethe4door)
check to see if you can see any cords or steel belt or nylon....if you don't see any of the above then take some rubber cement and glue it back....... if you see the above mentioned take it back to wear you bought it and get it replaced under the road hazard warranty
Old Aug 29, 2006 | 05:20 PM
Default Re: hit a curb, sliced my tire (vtecsi00)
nah none of that... no takin em back either... bought em second hand with stickers still on em... rubber cement it is
Old Aug 29, 2006 | 05:27 PM
FalkenSiR's Avatar
rubber cement:
Old Aug 29, 2006 | 05:36 PM
rubber cement... thnx
ttt
Old Aug 29, 2006 | 05:58 PM
nsxtasy's Avatar
H-T Order of Merit
Rubber cement isn't going to work.
And there usually aren't any belts or cords on the sidewall.
How deep is the chunk?
Old Aug 29, 2006 | 09:47 PM
its about the size of a fifty cent peice around and about 1/4" deep... i was just gonna slice it off with a razor very carefully, but i would rather glue it back on, if not for a lil protection, at least to make it look a lil better...
ttt
Old Aug 29, 2006 | 09:48 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (gottalovethe4door)
1/4" is pretty deep. I would replace the tire.
Old Aug 29, 2006 | 10:01 PM
vtecsi00's Avatar
Default Re: (nsxtasy)
yes there is nylon wrapped around the steel carcus of that tire.......and you can see them if it is deep enough...........
Old Aug 29, 2006 | 10:25 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (vtecsi00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecsi00 &raquo;</TD></TR><TR><TD CLASS="quote">yes there is nylon wrapped around the steel carcus of that tire.......and you can see them if it is deep enough...........</TD></TR></TABLE>
Are you sure about that? According to the diagram below, the nylon belts (shown in red and in gold) appear to only cover the tread area, not the sidewall. There are polyester body plies, though (maybe you're referring to those?). And some sizes have steel sidewall inserts, but others do not.
(Incidentally, I am assuming that the tire he is referring to is the Yokohama AVS ES100. There is no such thing as an AVS 1000. And BTW, it's spelled "carcass", not "carcus".)
I would still replace the tire...
Modified by nsxtasy at 3:08 AM 8/30/2006
Old Aug 29, 2006 | 11:24 PM
vtecsi00's Avatar
by the way polyster is spelled polyestar.......the nylon belt edge caps overlap the polyestar towards the sidewall of the tire for improved handling
Old Aug 30, 2006 | 12:09 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecsi00 &raquo;</TD></TR><TR><TD CLASS="quote">by the way polyster is spelled polyestar.......</TD></TR></TABLE>
No, it's not. It's spelled POLYESTER. Just like you see it in that diagram above.
(I corrected the previous typo, though. )
Old Aug 31, 2006 | 06:54 AM
Mangotreemechanic's Avatar
By the way, "carcus" is spelled carcass.
I think you are correct about "cords or steel belt or nylon" in the sidewall, because that is the sidewall support. Only they are called "body plies" and "steel sidewall insert". Only a minor semantics problem.
If the plies or steel sidewall insert ( I know they are steel wires) are exposed, then I agree with replacement of the tire.
Old Aug 31, 2006 | 07:33 AM
zguy95135's Avatar
Default Re: (Mangotreemechanic)
I would rather replace it, wouldnt be much fun to hit a big bump on the freeway and have it blow out.
Old Aug 31, 2006 | 09:41 AM
well i switcehd it to the back, and nothing is showing... on monday it held up fine @ 115mph sooo... i think ima leave it... i do wanna glue the patch back on though... rubber cement or super glue?????
Old Aug 31, 2006 | 03:30 PM
old man neri's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gottalovethe4door &raquo;</TD></TR><TR><TD CLASS="quote">well i switcehd it to the back, and nothing is showing... on monday it held up fine @ 115mph sooo... i think ima leave it... </TD></TR></TABLE>
Ah, of course, the Newfie way of testing a tire. Drive it as fast as you can and see if you die or not.
Just cause it didn't go this time doesn't mean it won't go the next time. There is a reason a tire like that wouldn't pass safety.
Cheers.
Old Aug 31, 2006 | 07:30 PM
vtecsi00's Avatar
Default Re: (old man neri)
rubber cement and be careful not to have a blow out at 115mph
Old Sep 2, 2006 | 09:13 AM
it was on the late night tip wit no one around on the highway...
Old Sep 4, 2006 | 11:11 AM
BuiltforSin's Avatar
dont be cheap.. you rather have your life, and spend $50 on a new tire or a quick fix and possibly end up endangering your life as well as others
mr95accord
Oct 5, 2014 07:32 PM
MrXclusivE
Sep 29, 2008 11:40 AM
imroadk1ll
Honda Civic (2001 - 2005)
21
Feb 28, 2007 05:00 PM
sporty240
Aug 17, 2005 04:35 PM
erikiksaz1
Sep 5, 2004 10:14 PM
