okay, quick ? about lowering springs on DA...
Old Aug 29, 2006 | 04:22 PM
Dee A Nine's Avatar
Default okay, quick ? about lowering springs on DA...
Do aftermarket lowering springs neeed a spring compressor to take out?
Old Aug 29, 2006 | 04:25 PM
atg1290's Avatar
to remove the spring? If so it would depend on the spring and how much it is compress by the shock assembly..If it move freely then yes and be safe!
Old Aug 29, 2006 | 04:27 PM
trick_db's Avatar
Default Re: (atg1290)
nah you dont need too, well try to push it down see if is soft enough to take it out without using the compressor, but im pretty sure you can take it out without using a compressor, i just took out my sprint springs over the weekend without using a compressor
EFinawesomeman
22
Aug 7, 2007 08:03 PM
HondamanXxX
19
Jun 21, 2007 04:30 PM
EK4nut
Suspension & Brakes
Jun 13, 2007 02:51 PM
Dee A Nine
Suspension & Brakes
Aug 29, 2006 05:52 PM
CRX-RX
Jan 23, 2002 10:49 AM
