Valve adjust.
http://www.c-speedracing.com/h...t.php
ok i found that link but it says b18c , im trying to do one for a b18b (94 integ) i knwo it says "follow for all other b18's" just making sure.. dont wanna f nothing up
SAME STEPS BUT THE VALVE CLEARANCES MAY BE DIFFRENT BETEEN B18b AND B18C. CALL THE DEALER TO MAKE SURE BUT THESE CEARANCE SHOULD BE WHAT YOUR LOOKING FOR. Intake 0.15 - 0.19 mm (0.006 - 0.007 in)
Exhaust 0.17 - 0.21 mm (0.007 - 0.008 in)
For a b18b, the valve clearances are:
INTAKE: 0.003" - 0.005" (0.08mm - 0.12mm)
EXHAUST: 0.006" - 0.008" (0.16mm - 0.20mm)
Also with the b18b, which is not mentioned on the cspeedracing guide, is you do not need the bent wrench. A regular wrench will do.
