Transmission Hub/Sleeve Install
Old Aug 29, 2006 | 02:43 PM
zCivic's Avatar
Default Transmission Hub/Sleeve Install
Ok 2 quick question about installing these. Both the 3rd/4th and 5th synchro hubs have dots in one corner (of a circle yeah I know). Do the dots face towards the inputshaft or towards the bearings. Second is the 3rd/4th Sleeve one of the lips has a groove cut into it does that face the input shaft or the bearing. I've enclosed some ghetto pictures from the old trusty phone.
Old Aug 29, 2006 | 03:09 PM
Gearspeed-Performance's Avatar
Default Re: Transmission Hub/Sleeve Install (zCivic)
The groove will be facing down towards the clutch housing The hub will have what looks like a "U" on it which locks the hub from going to far up...that should be down (upsidedown "U") If it is the S-1 the dot will be facing up on the hub.
Modified by GearSpeedEF7 at 2:28 PM 8/30/2006
Old Aug 29, 2006 | 03:17 PM
zCivic's Avatar
Default Re: Transmission Hub/Sleeve Install (GearSpeedEF7)
So I have the Sleeve backward the groove goes towards the input shaft and these hubs don't have a "U" on any of the teeth. Its a 90-91 cable so I'm not sure if this makes a difference or not.
Old Aug 30, 2006 | 02:08 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
yes it's upside down in reference to the way it is in the picture. on the 5th/R hub, the shallower side is reverse end and the deeper side is 5th side.
IN VTEC
Aug 24, 2010 03:44 PM
kornerk12
Jul 29, 2008 04:51 PM
stealth_EK4
Honda Civic (2001 - 2005)
Apr 11, 2008 08:23 PM
servion
Apr 26, 2006 08:56 PM
TurbodCX
Apr 30, 2003 08:40 AM
