Battery relocations (not the trunk)
Old Aug 29, 2006 | 02:39 PM
Kagelude's Avatar
Default Battery relocations (not the trunk)
Anyone know where i could find a kit or write up for the repositioning of the battery in the engine bay. I know this can be done but i haven't been able to fine any write ups or info on HT.
edit: i still looking it up, it think its called tucking the battery, anyone know i can't find any specifics
Modified by Kagelude at 3:58 PM 8/29/2006
Old Aug 29, 2006 | 03:28 PM
petern101's Avatar
Default Re: Battery relocations (Kagelude)
i dunno about tucking
but why don't you just buy a slim battery. you can put those almost anywhere or free up some more space where the battery currectly is
Old Aug 29, 2006 | 03:40 PM
98vtec's Avatar
moderator emeritus
Default Re: Battery relocations (petern101)
pm DarkBB4
Old Aug 29, 2006 | 05:33 PM
Kagelude's Avatar
Default Re: Battery relocations (98vtec)
Thanx guys for the replys, do you know where i'd be able to find a slim battery. just to add as and option
Old Aug 29, 2006 | 07:18 PM
petern101's Avatar
odessy is one of them.
i hope you don't run alot of electrical stuff other than normal. because some lightweight / slim batteries are for racing apps and less cranking power.
Old Aug 29, 2006 | 07:27 PM
BB6racer's Avatar
i was thinking about the odyssey battery but after doing some reading i found that people are having trouble on daily driver cars. people were saying that they die easier than normal size batteries and have to be jumped all the time. just a little FYI...
Old Aug 29, 2006 | 09:01 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kagelude &raquo;</TD></TR><TR><TD CLASS="quote">Thanx guys for the replys, do you know where i'd be able to find a slim battery. just to add as and option</TD></TR></TABLE>
Interstate Batteries stores carry Hawker Odyssey batteries.
I have one mounted where the under-hood fuse box normally goes. I bought a small battery tester/charger to keep it the battery up to speed because it does die easier than a normal battery, leaving your lights on for a little while kill it. It probably also would not work if you have a stereo any bigger than stock.
It does start the car just fine, though.
Old Aug 29, 2006 | 09:34 PM
MadCityLude
Guest
Posts: n/a
Default Re: Battery relocations (Hawkze_2.3)
What about STINGER? Anyone using them? Are they more reliable than the odyssey? They are smaller and lighter than stock also, but designed by a car stereo specialty company? Anyone?
Old Aug 30, 2006 | 05:33 AM
prelittlelude's Avatar
i removed all the old battery mounting junk and just use an integra battery and droped it down right infront of the tranny, and built a box for it. so now it sits BELOW the frame rail height and is still in the engine bay. i did all the fab myself so cost me nothing other than a integra sized battery. fits even with plety of room next to the radiator.
Old Aug 30, 2006 | 06:20 AM
Finest's Avatar
Default Re: Battery relocations (prelittlelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude &raquo;</TD></TR><TR><TD CLASS="quote">i removed all the old battery mounting junk and just use an integra battery and droped it down right infront of the tranny, and built a box for it. so now it sits BELOW the frame rail height and is still in the engine bay. i did all the fab myself so cost me nothing other than a integra sized battery. fits even with plety of room next to the radiator.</TD></TR></TABLE>
PICTURE! ASAP!
Old Aug 30, 2006 | 06:33 AM
Default Re: Battery relocations (Finest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finest &raquo;</TD></TR><TR><TD CLASS="quote">
PICTURE! ASAP!
sorry man, i should have taken some , but the reason i dropped it down way because i needed all that space and now its all covered, so too late for pics
it sits right next to the frame rail partly on the very front cross member and right next to the raditor.
Old Aug 30, 2006 | 07:48 AM
prahjekt's Avatar
Any reviews on the Braille or Buddy Club battery?
Modified by prahjekt at 12:27 PM 8/30/2006
Old Aug 30, 2006 | 07:52 AM
tacticalcustoms's Avatar
Default Re: Battery relocations (prahjekt)
stinger are highly reliable batteries. Alot of the car stereo suppliers in the 801 switched from selling optima to stinger because of better quality and reliability.. I myself soldmy red top optima and got a stinger and have never looked back.. maintence free. etc.. thats just my 2 cents.
Old Aug 30, 2006 | 08:20 AM
Kagelude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petern101 &raquo;</TD></TR><TR><TD CLASS="quote">odessy is one of them.
Naww standard stereo, nothing special
Old Aug 30, 2006 | 08:27 AM
Kagelude's Avatar
That sounds like the better way to go for me. I'm not really liking the though of needing a jump every now and then. i like to listen to music with the car not running at the wash. would you be able to do a small write up on that
Old Aug 30, 2006 | 08:29 AM
MadCityLude
Guest
Posts: n/a
What did you do with the coolant resevoir! It mounts on the battery box!
Old Aug 30, 2006 | 08:45 AM
Kagelude's Avatar
Default Re: Battery relocations (MadCityLude)
x2... i did notice that when i did the civic radiator conversion
Old Aug 30, 2006 | 11:59 AM
20_00_pre_lude's Avatar
http://heeltoeauto.com/NRG-CEL....html
i havent heard of anyone that used it but it was in a post before.....
Old Aug 30, 2006 | 12:21 PM
DarkBB4's Avatar
Default Re: Battery relocations (20_00_pre_lude)
Hey.. i repositioned my battery and made all my own cables... it was easy.. pretty cheap.. and didnt have run lines all the way to the trunk!.. .here are pics....
I bought an autozone battery mount... mounted it to subframe... then used 2 pieces of hand-crafted alumunum pieces... (like 9 degree bends) and when its tightened it presses against battery.. so it doesn't move at all!!!
couple pics.. although doesnt' help too much sorry
Old Aug 30, 2006 | 12:37 PM
Kagelude's Avatar
Default Re: Battery relocations (DarkBB4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkBB4 &raquo;</TD></TR><TR><TD CLASS="quote">Hey.. i repositioned my battery and made all my own cables... it was easy.. pretty cheap.. and didnt have run lines all the way to the trunk!.. .here are pics....
yes.. your car is the reason i started this thread, i saw it in the prelude pix thread and wonder how that was done.. thanks for the post. your bay looks so clean
edit: how did you get the reservoir to stay there like that??
Old Aug 30, 2006 | 01:01 PM
Kagelude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 20_00_pre_lude &raquo;</TD></TR><TR><TD CLASS="quote">http://heeltoeauto.com/NRG-CEL....html
i havent heard of anyone that used it but it was in a post before.....</TD></TR></TABLE>
Very nice, good find.. i'll look into it more thanks
Old Aug 30, 2006 | 01:14 PM
IAluder95's Avatar
whats the life of that battery. for 118 bucks....
Old Aug 30, 2006 | 02:17 PM
Kagelude's Avatar
Default Re: (IAluder95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IAluder95 &raquo;</TD></TR><TR><TD CLASS="quote">whats the life of that battery. for 118 bucks....</TD></TR></TABLE>
read this
http://www.acurazine.com/forum....html
based on what is said by this rep, those batts are suppose to match or exceed oem. but he doesn't give any specific numbers
Old Aug 30, 2006 | 02:30 PM
xiaogou's Avatar
Any idea on the weight of the NRG?
Old Aug 30, 2006 | 02:55 PM
flipwhip's Avatar
Default Re: (xiaogou)
11.5lbs
