F20b into a DA questions.
Old Aug 29, 2006 | 01:35 PM
ComptonsF1NEST's Avatar
Default F20b into a DA questions.
Ive been looking at swaps and i want to try and F20b into a DA.
Now some things ive thought of along the way.
What Trans to use - was thinking the cb7 cable trans?
What Clutch to use?
Does Uberdata have an F20b program?
What axles to use?
I plan on using Explicit Speed H22 mounts. Will they all bolt up to an F sereis? I understand that there will be some problems with certail clearances, im expecting with the firewall, almost 100% sure of that. Nothing big enuff that a hammer wont fix or even a shorter intake manifold.
Also, the alternator. I will probably need to fabricat a bracket??? or re drill the h22 one? The reason for this is i want to have h22 like power on the F series sleeves, which, by looking at the f20c are strong as hell.
Any insight to this swap will be appreiciated.
Old Aug 29, 2006 | 01:54 PM
ExplicitSpeed360's Avatar
Banned.
Default Re: F20b into a DA questions. (ComptonsF1NEST)
As far as I know the F20B will drop in the DA chassis with our DA H22A motor mount kit...
Don't worry about the alternator/tensioner bracket...our kits include your choice of D or H series alternators...our alternator/tensioner kits fit on the F and H series blocks...
As far as clearance on the firewall and the H22 should be no problems just like our EF H22A kit...
Axles:
90-93 Acura Integra driver side
90-93 Acura Integra passenger side axle with Accord inner joint http://www.Raxles.com
90-93 Honda Accord F series Ex or Lx model midshaft 94+ may also work...
Cable/Shifter Assembly: 90+ Honda Accord with cables and or 92+ Prelude with cables
As far as transmissions I would go with the H22 transmission shorter gears then the H23 and F series...a good used usdm H22 transmission runs about $300-400...
As far as clutch a stock replacement will work fine but if you decide to take to the track a stage 1 or 2 would be a good idea...
Crome has base maps you'd want a map for a H22A program...p28 ecu will be your best investment...
Please PM me with any other questions regarding the swap...
Old Aug 31, 2006 | 05:33 AM
do u use an H22 header?
Old Sep 1, 2006 | 08:41 PM
ittt
EJ-1
Aug 20, 2010 08:26 AM
turtleman321
May 3, 2010 06:32 AM
pullin crx hf
Sep 9, 2009 01:20 AM
702egsi
Oct 24, 2007 05:19 PM
XLR8_HFX
Jan 25, 2006 02:12 PM
