which timing gun do you use?
Old Aug 29, 2006 | 01:31 PM
RACEPAK's Avatar
Default which timing gun do you use?
hello fells.
i want to buy a timing gun. with display and everything.
which one would you reccomand in the range of $70.
thanks.
Old Aug 29, 2006 | 02:25 PM
thesmogman's Avatar
Default Re: which timing gun do you use? (RACEPAK)
I have the $90 dollar one from Kragen and I have put it to the test. It passes all my tests for the last two years. Innova 3568+
Spend the couple bucks for the digital, it is worth it.
Old Aug 29, 2006 | 02:28 PM
IN VTEC's Avatar
I went from using a Craftsman with advance to the Equus 3568. It has a digital display that shows RPM and advance. It's lightweight and plastic, so you never have to worry about it grounding out on a PS line or other metallic parts.
80strucksrule7
Jul 31, 2012 02:58 PM
kixcrx
Nov 10, 2006 10:33 AM
aron0903
Aug 4, 2004 12:34 AM
MikeTV
May 5, 2003 08:15 AM
